Hi Duncan
The head work does not have to be done if I do not want it, I asked him to quote to see what else could be done as it will be the time to do it if I want it .
I will ask him about what you have all said
BUT if it was done as is, HOW would it be, would it drive well on the street ?
No idea mate, I've never driven a car with a ported head. But what I expect is it will flow better at high revs at the cost of low rev torque. Same effect with larger valves; they are both about making top end power.
Hi Duncan
That is basically what he said, it will be torquey, but the head work will also give me some extra top end power.
I was not really wanting to know about the head work, I was asking about the total build in general.
It is going to have a lot of response and with the head work it should keep going at higher revs.
I was told by a bloke I respect that I should change the cams to 260 x 10.8 and I am thinking of doing that but I would like to know how it will be with the list I posted????????
Thanks
Pete
Just run a SS Alpha Variable geometry turbo. That will gives you both down low and up top. Use it on stock engine, factory cams and factory cam gears. Saves heaps of marking around also.
Never heard of them and I will check out your web site, why isn't everyone using them , cost too much, not reliable, hard to get, load of crap or not in the main stream yet?
Must be a great Turbo to be able to do that but how do the standard motors like it and without all of the other things that combine to make a tough fast car reliable?
From what I could find out, once you get something like 3.2 stroker you will need the air to flow free at the top end or it could choke.
But interfere with your response? maybe help it?
A proper port job by someone who knows what they are doing won't sacrifice anything.
Which means not needlessly enlarging the ports which hurts gas speed.
It will gain everywhere.
It's way more complicated and time consuming to do it well than most people can imagine.
If I had the cash I would definitely get a gun head porter to work their magic.
Edited by Ben C34
VNT systems are not yet the main stream performance turbochargers because the years in practice of the ideology by OEM manufactures is not in high performance field. So it comes down to who made it for what purposes. The most important engineering element of ours is reliability, In which you find all sorts of reported turbo failures except ours.
The development of VNT turbine system has been welly documented, Starting from:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-390
Check thread index for final outputs. This covered three types with peek power rating from 380rwkws to 490rwkws. Most of evaluations was carried out based on a Rb25det motor, I'll be more then happy to offer free trails if you are in Melbourne.
Hi Ben, That's what I thought from what I have found out so far, if anything help at both ends?
Hi
I edited my previous post and added more info.
Typically the area they work on the most in the bowl, behind the valves. It's not unusual for the ports themselves to be barely touched.
Most people want to just hack open the ports, which is not the way to go.
A "race port" is extremely vague, as most performance talk, but I'm sure as the engine builder knows your desired outcome they will be porting the head as required.
Certainly people make big power with untouched heads, but there is no doubt that a well ported head will make more power everywhere.
Hi
It is CRD full race port head RB26
So its designed to flow at high RPM at the expense of bottom end torque.
Full Race ported heads genrally have poor low speed velocity flow.
Saying race head can be very vauge as mentioned, a mild clean up without opening runner size would be far better suited to a street application.
One mans race head and anothers are totally diffrent.
Are they deshouding the valves by removing some of the quench pads?
Hmmm have you budgeted for a stronger one, I think it would be wise. Maybe something you should discuss with CRD if you haven't already done so.
I was under the impression the GTR gearbox was pretty tough and most blokes are running with them?
What do you use??
What do you use??
Just a standard 33 box in a 26, but I haven't got the torque that you will have, no where near. The torque is what should be considered rather than the power. Just something to investigate anyway. You don't want to be smashing the box first up and have to wait to get one built if it's your dd.
I had better do some homework, thanks
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
