G`DAY ALL,Had a chat with Brad about another track day ,This time we need to have ALL STAGEA .Most said thatthey wanted this so come on let`s get it on ,post up WHAT DATE`S YOU THINK ???,WE ARE LOOKING AT SEPT,SO LOT`S OF TIME TO GET ARE SHIT TOGETHER ,cheer`s chuckie.
https://www.sau.com.au/forums/topic/224732-ahg-track-day-stagea-only/
G`day Dale yes hope to be out for this one as iam feeling better,so hope we will get number`s for this ,date`s will not clash with football final`s if i have anythink to do with it ,i will speak to brad & see what`s about date wise .so we should have number`s ,if people will get on broad ???.this is for you to learn about you & your car ,so there is many WHO will get a lot out of it Me as well,iam looking forward to having a day out give car a good workout :thumbsup: so come GIRL`S this will be great for you .just post up what your looking for ok . IT WILL BE ON WEEKEND, am i would like , cheer`s chuckie
i thinkk 16 is the max but u can have less. just means u pay more as u hire out the skidpan for a few hours..
not shure if i will go in for this one as i dont think i would take away any more knowledge than last time. still would come down for a looksee
I dunno man, last time you got sooooo close to dragging your front bar on the ground, with applied effort I reckon you could get there :blush:
G`day All if we don`t have number`s then it will not happen ,i have no worries if it doesn`t ,IT`S up to you if this is to GO AHEAD so GOOD LUCK in getting it up we have the number`s here so what`s wrong with every one ?????,come on get on broad & get the number`s up .cheer`s chuckie.
we might physically have the numbers - but it all comes down to time - money and enthusiasm - a elusive trifecta to get to happen all at once with most people
but I put forward the idea to loretta so hopefully put us down..
oh and you might want to edit 1st thread wtih yes no's / maybe's
Brad, you could start off with a brand new set of BFG Desert Duellers on the back, and they would STILL be low profile slicks by the time you were finished...
If only this was open to other cars :O
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
