Item: r33 series 1 wing with working led light
Condition:great no damage
Price: 80
To Fit: (What car) r33
Contact:josh
Comments:removed to fit series 2 wing
will post at buyer expense
Item: r33 stock intercooler only no pipes
Condition: good
Price: 50
To Fit: (What car) r32,r33
Contact josh
Comments: only removed to fit FMIC
Item: exhaust
Age: unknown
Condition: good
Price: 90
Contact josh
Comments:its has 3inch inlet with 5 inch tip
Item: series one front bar
Condition: ok and had abit of damage which has been repaired but will need respray to be perfect
Price:130
To Fit:r33 series 1
Location Brisbane
and here is what i will swap for turbo timer, oil catch can, clear side indicators, blown stock r33 turbo or something else of interest
Edited by Turbo 33
https://www.sau.com.au/forums/topic/227581-r33-gtst-parts/
new part added
Item: stock r33 dump pipe and front pipe
Condition: good
Price: 70
To Fit: r33
Contact josh
Comments: removed to fit 3 inch split dump pipe
https://www.sau.com.au/forums/topic/227581-r33-gtst-parts/#findComment-4008452
Price: 80
Contact:josh
Condition: good
Price: 50
Contact josh
Item: exhaust
Age: unknown
Condition: good
Price: 90
Contact josh
Price:130
To Fit:r33 series 1
Location Brisbane
Condition: good
Price: 70
To Fit: r33
Contact josh
and here is what i will swap for turbo timer, oil catch can, clear side indicators, blown stock r33 turbo, electronic boost controller or something else of interest
Edited by Turbo 33
https://www.sau.com.au/forums/topic/227581-r33-gtst-parts/#findComment-4009721
bump price drop
Price: 60
Contact:josh
Condition: good
Price: 40
Contact josh
Item: exhaust
Age: unknown
Condition: good
Price: 80
Contact josh
Price:120
To Fit:r33 series 1
Location Brisbane
Condition: good
Price: 50
To Fit: r33
Contact josh
https://www.sau.com.au/forums/topic/227581-r33-gtst-parts/#findComment-4013247
take all this for 300
stock suspension that i just brought from wreckers to clear defect
stock dump front pipe
exhaust 3inch inlet with 5 inch tip
2 stock intercoolers
series one wing without led light
i need the money to get a new clutch as the stock one just shit itself on saturday
Edited by Turbo 33
https://www.sau.com.au/forums/topic/227581-r33-gtst-parts/#findComment-4042781
stock suspension $120
stock intercooler no pipes x2 $50 each
stock dump front pipe $60
series 1 wing only no led light $80
exhaust 3inch inlet with 5 inch tip $90
will post at buyers expense
https://www.sau.com.au/forums/topic/227581-r33-gtst-parts/#findComment-4057997
  • 4 weeks later...
  • 3 weeks later...
  • 2 months later...
Price: 60
Contact:josh
Item: r33 stock intercooler only no pipes X2
Condition: good
Price: 30 each or 50 for both
Contact josh
Item: exhaust
Age: unknown
Condition: good
Price: 80
Contact josh
Item: stock r33 front pipe
Condition: good
Price: 20
To Fit: r33
Contact josh
will swap for parts of interest like r33 gtst clear side indicators , turbo timer ,r33 gtst el white dash dials and other parts just throw me and offer
Edited by Turbo 33
https://www.sau.com.au/forums/topic/227581-r33-gtst-parts/#findComment-4315942
Price: 60
Contact:josh
Condition: good
Contact josh
Item: exhaust
Age: unknown
Condition: good
Price: not selling know
Contact josh
Condition: good
Price: 20
To Fit: r33
Contact josh
will swap for parts of interest like r33 gtst clear side indicators , turbo timer ,and other parts just throw me and offer
will swap for r33 gtst parts like steering shroud,
the plastic bits the go from roof to floor in the middle of the car
all boot trim
parcel shelf
drivers side door trim and passenger side
handbrake rubber thing gearstick boot gear stick plastic
pretty much any interior parts let me know what you have and we can work something out
clear side indicators or smoked ones
turbo timer
Edited by Turbo 33
https://www.sau.com.au/forums/topic/227581-r33-gtst-parts/#findComment-4331742
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
