heres a picture of mine. for some reason the front guards are strange.. the bottom of the guard where the side skirt meets it is narrower than the factory one and leaves quite a big gap
behind the wheel. dont know if they were made that way intentionally??
reduce your caster to close that gap (if you have aftermarket caster rods
they dont look finished in that picture, there is no clearcoat im guessing on those guards, not a bad job mate, i appreciate the effort it takes.
Yeah whats with the paint on the gaurds? Bit hard to tell from the pic. No clear?
lol nah mate its not the final coat just temporary, cause of the fact that im attempting this myself it still hasnt reached that stage yet theres still minor touch ups then prepping left to do which will take awile.also ive had to customise everything since they were made for gtr.which was a real head ache
and thanks craved ill have to get a set of those to fix that gap,
i could explain why the fronts dont look right but thats another story
I bought a set of front DMAX guards for $550 delivered to my door. They fit fairly well with only minor sanding needed. A couple of small issues though,
The indicator hole did not quite fit the indicator so had to silicon them in instead of using the clips and the mounting screws under the bonnet could not be done up too tight without cracking the fibreglass. Apart from that I was happy with the fitment.
Oh also one guard had a small crack in the wheel arch which cost me $100 to get repaired.
damn thats expensive for a small crack!! :D
BLK33t referring to your comment no you cant not without modification anyway.
oh and can someone enlighten me as to why my rear guards look dodgey??lol :blink:
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
