Hey there,
I'm thinking about getting a R32 skyline and put my RB30 that's being built into it rather than keeping my 180sx, as i want more even weight ratios.
But i was looking at www.imports.motortraders.net after i read some where that 1989 to 1991 skylines are lighter than the other ones.
May 1989 to 1991
Weight 1260kg
August 1991 to 1992
Weight 1320kg
So i was thinking;
What did they do to make it heaver?
Is there a way to make the newer models lighter?
If not would it be better to get a later model skyline as it would have better weight distribution up front with the RB30 and RB25 gearbox in it?
Thanks,
Andrew.
https://www.sau.com.au/forums/topic/242524-r32-choices-and-weight/
From what ive read, the series 2 r32 (1991-1993) had factory side intrusion bars installed into the doors.
Any series 1 r32 imported into australia, gets the bars fitted in during compliance, so in the end there is no weight differences.
The series 2 has different steering wheel design, different fabric, different colour dash fascia and different plastic interior (bumpy instead of smooth).
Plus other small little bits, but all these changes wouldnt affect greatly the overall weight of the car.
So side intrusion bars added 70kg?
im not sure what else could add weight to the car.
From my understanding, everything is pretty much exactly the same apart from some slight interior changes.
However perhaps someone would be able to shed some more information?
A mate of mine weight his skyline and its around 1250 and his is a 1990 so even when there imported here there still lighter than the newer models with the side intrusion bars.
So is it just the complete car that weights it because the way the chassis is made or is something added :S
Would it be better to go the older one then, as its lighter over the newer ones?
i have massive sub box and 2 amps = 60kg
full tank petrol waht = 60kg
2b25det and box + 100kg?
25 l of old oil going to dump = 25 kg?
my fat ass = 110 kg
gtr wing lol = 10 kgbut yeah how accurate is dump weigh bridges
and u have coolent and oil and fuel to add on to your dry weight
and i have 18's and gtt breaks got to be some more weight there
cooler etc?
No one knows why the new ones are heavier?
Or if some one has weighed there newer R32 to see if its true?
I don't mean to sound rude, but no one will be replying to this thread because it is completely useless! You're only talking about a matter of 60kg. I work for a manufacturer that updates each model constantly and has a face lift half way through a particular models run (new model every 7years so facelift usually after 4 years to improve the car and boost sales again). This is not a new concept and I'm struggling to understand why you cannot grasp it. A control unit can be superseeded up to 6 times in only one year. each time the supplier, casing, hardware, software (weight) can change with each item.
Your answer is simple but very long and boring = different composition of plastics, more sound deadening, different wiring looms, chassis strengthening down to the grade of metal used to make the car itself.
All these thing could easily make up 60kg.
Why do you care anyway? If you're going to put an RB30 in anyway, even a mildly warmed over example is going to pull a 32 along with ease. +there are many roads to travel to lighten a car if that is what you are concerned about.
(As said above) 48 + 62 = 110 and there is no way on earth that a silvia has a wieght distribution biased towards the rear! A S8 RX7 is one of the best weight distibuted cars to come from japan at 51/49%. why do you think all the serious time attack cars have the engine lowered and moved back towards the fire wall in a silvia? Let alone a skyline, which is heavily front weight biased due to cast blocks etc.
If you are trying to figure out which model to buy for your build than do some research on something a bit more poignant like which one will the RB30 slip into easier? With out ever looking into that myself, I would imagine a 1993 version that has or had an rb25de in it so all you need to do is swap the bottom end, fit the turbo gear and remap the standard ecu. Obviously it won't be that straight forward but it will go a long way to making things a lot easier.
Rant over :huh:
  • 3 years later...
i know this thread is f**ken old as, But if you (ellie) where not meaning to be rude then why the f**k talk down to the fella asking the question in the first place?, clearly he was curious and wanted some insight, just becuase you work in the field and "know it all" doesnt mean other people know and understand what happens and why. So to a person who doesnt know and wanted some insight be a lot f**king nicer you repugnant f**k!
And the user was last active:
Last Active Aug 14 2010
So the chance of you seeing the somewhat pointless post/bump/whatever... Are highly unlikely. No need to post that, and certainly no need to swear your knackers off either. It's long since dead, next time leave it that way.
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
