Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
my t04z is a split pulse t4 flange - same as the GT3788. The 4088R is a bigger turbo than the T04Z (compressor and turbine) so it will flow more HP, with a tiny bit more lag.
Main reason for doing the swap is simply that the Z is too doughy out of medium tight corners around the track. IE: turns 3/4 @ QR I take at about 80km/hr. 2nd gear == massive tailslide on exit, whilst 3rd gear == LAG all the way out of the corner. Hopefully the new turbo is not only slightly more responsive, but a lot more linear in power delivery. I make 1 bar at 4100rpm with the Z and 24psi at 4500. Thats not too laggy, but as soon as you go below 4000 rpm there is absolutely nothing there. I wouldnt care too much if the 3788 only makes 1 bar at 4000rpm as long as 3800/3900 still had SOMETHING available unlike the Z which comes on like a lightswitch once you get over 4.
The only unfortuante thing is that I wont be able to directly compare how the 2 turbo's would have worked on the track as I'm making some other significant changes to the car at the same time. So wont be able to say if the 3788 is soley responsible for better lap times, but hopefully combined with everything else we are doing it makes a big difference.
Still probably a couple of weeks away from doing the swap - will see how we go.
What else are you doing mate!?!?!!?!?!?
Is it going to be ready for the 11th?
We are going to run high boost on the T04z this time and see what we can times we can squeeze out of it.
Hopefully the new balancer will keep all the belts on the car unlike last times sad effort!
#### Couldnt edit my first abortion of a sentence.
this should make more sense
We are going to run high boost on the T04z this time and see what times we can squeeze out of it.
Oh few bits and pieces. Got some softer suspension going in as the 12kg springs that were on there were way to hard. The car will definitely be there on the 11th even if i have to push the damn thing around the track :D
hopefully catcha then ! Look forward to seeing what you can do with the good ole Z :P
Oh few bits and pieces. Got some softer suspension going in as the 12kg springs that were on there were way to hard. The car will definitely be there on the 11th even if i have to push the damn thing around the track :banana:
Nice mate,
Looking forward to seeing your new setup in action!
Wont be able to say if the 3788 is soley responsible for better lap times, but hopefully combined with everything else we are doing it makes a big difference.
Are you running an RB30? 1bar at 4100rpm isn't that bad :thumbsup:
Strictly speaking the GT4088R isn't really a bigger turbo than the T04Z, the T04Z has a bigger compressor which wants to flow a bit more air - the Supra guys in the States and the UK seem to be increasingly moving from the T04Z to the GT4088R as the fun 700+ish turbo to have, the GT4088R is apparently more useable and generally fun.
Look forward to hearing how the GT3788R treats you, I've never heard of one used on a petrol motor.
sounds like rb26 response.... in 4th gear on a flat road loading up the motor i was getting 1bar around 3700rpm on my stock capacity rb26
Smoking Crack whilst driving helps Cerbera think the boost is coming on sooner.
Also Cerbs .... 139mph last night with a GT35 !!
ANDRA guy got angry and told me to get a chute ..... jeeeeeez never ends !
Good job, I guessed your weight at 2800lb?s and put your run in the Power calculator and it came up at 560hp so the numbers sound right.
http://www.turbofast.com.au/Drag.html
Reasonable guide but remember its engine power. Im surprised just how close this has been.
dam id love to see a skyline run 139 at the plex, where are u getting ur E85 from in perth?
silvia even
Edited by ahh 33 s2
Running 1000cc injectors and low rail pressure. It gets to 90%.
Not sure how the pump would fair on higher rail pressure but in theory a lot more injector available.
Are you running an RB30? 1bar at 4100rpm isn't that bad :P
Yea, the compressors of the 2 turbo's are fairly similar in the scheme of things ->
TO4Z
Inducer 66.7mm
Exducer 84.0mm
Turbine: 74.2mm
4088R
Inducer 63.5mm
Exducer 88.0mm
Turbine: 77.0mm
Doesn't the exducer determine how much air it can flow ? People seem to be getting a bit more HP out of the 4088's than the Z's.. the fin design of the new garrett turbo's is more efficient than the older Z's.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
