1 hour ago, dyl33 said:
Is anyone using turbo inline oil filters in 2020? Thoughts?
I brought one with my @hypergear turbo but am unsure if i should use it.
There's lots of mixed opinions what do you guys think?
I run one, put it this way if your motor lets go and sends bits of metal into your oil system do you also want it to take out your turbo?
Just insurance for the turbo CHRA.
  • Thanks 1
16 minutes ago, dyl33 said:
Yeah that's how i would of thought it goes together. But i only have 1 line
So somthing like
Block>fitting>union>filter>line>turbo
I do not know
Well that will work looking at the pic so long as it fits
46 minutes ago, GTSBoy said:
Yuh, that filter clearly meant to go on the block, assuming that the hose in the photo is both ends of the same hose.
Yes the hose is the same one.
So block>fitting>union>filter>hose>turbo
And does the union need to go a certain way one end is a little longer?
Thanks
What do you mean "one end is a little longer"? Are you talking about what you can see on the outside, or what the internals look like? Given that the cone end on both the fitting and the filter appear to be the same length, I would expect that the union would need/want to be the same both ends internally. The difference in length in the external hexes is really just to provide the room for the union swivel (I should imagine).
