I got a stock R33 s2 it has the side mount intercooler and i just recieved my http://cgi.ebay.com.au/Turbotech-manual-tu...A1%7C240%3A1308 wat is a safe level above stock that i can put my turbo too? also does any1 know how to install this thing? :) i'm noob :(
Edited by J4M3S
https://www.sau.com.au/forums/topic/246506-how-high-is-safe/
I ran at 14 psi with no problems but then it wasnt at WOT for to long, ((Ive swapped it out now for a TO4 with a 68 rear (WHICH IS STILL TO BLOODY LAGGY)) and upon inspection the bearings were still ok.
But in the end i must add how has the car been maintained (oils), how long will you hold it at full boost (giving it a bit here and there or draging)
If your turbo blows up dont blame me,LOL.
For peice of mind you could always buy a spare in case of a failure, I sold one for $200 i think a while ago so for a cheap power up grade its good value for money.
WOT??...T04??? sorry like i said i'm noob i'm still trying to pick up the short hand
WOT = wide open throttle, to4 is just a bigger turbo.
You need a good boost gauge and when you up the boost do it in small increments or you will end up running at 20 psi and it will blow.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
