^^ Danny with age like that on your side you may need to retire and mod down to a RB25DE hahaha
The elderly and turbos do not mix unless attached to a 2.5L Diesel towing a caravan ;)
On another note when is the next wreck coming in???
  • 2 months later...
I got defected by a wanka cop for bov, blue parker lights and low beam turning off when high beam is on which is factory stock not a wiring problem he also thought the turbo timer was a boost contoller! the cop then said i have a week to take it to regency! I explained i only just bought the car 3 dsys ago and was gonna change the stuff! I asked why i couldn't take it to a cop to get the deffect off! He said caus there not mechanics they don't kbow what there looking at! I asked if he was a mechanic he said no then i said well how do you know what your looking at! He then ssid get smart with me ill arrest you an fine you 500 for driving a deffecable car i said you can't do that!
turbo timers are an instant defect, illegal on sports cars and they're a waste of money. well they can fine you $150 dollars for each defect they find. there is no set time frame you have to "get it to regancy" even if it runs out of rego just get a day permit.
To the guys out there that run a greddy intake manifold, have you even been defected for it? Or can you get defected for it??
Cheers
Get an idle emissions test and send in an application to modify your vehicle, they will come back saying you need an emissions test, once you have that you can go to regency to have it inspected and then you will get a nice piece of paper to put in your glove box saying you are A-Ok, if not then you are up to the mercy of the cop.
Actually even with the piece of paper you are up to the mercy of the cop.
You can get defected for your exhaust not looking standard, you can get defected for things that do no even physically exist on your car so if they want to defect you, they will.
Basically if you draw the wrong sort of attention, guaranteed defect no matter the condition of your car.
Edited by Rolls
Just play the game as best you can and don't drive like a dickhead and more often than not you will be fine. I got an application to modify my car with all my mods listed, idle emissions test and keep the inspection record in my glovebox, if your car looks stock, you show them this and don't act like a twat you'll be fine the majority of the time,
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
