Gear Box Breather
PIOTREK
 Share
  • 4 months later...
did anyone try to change ta another brand? and did that help?
i have the same problem, had a bunch of other brands before then after one change it started to spit out of the breather.
Yes and yes. You can change the oil or extend the breather as above.
  • 1 year later...
Let me revive this thread.
I've been having this issue with my rb25. Oil leaking out of my tranny breather hose. Yesterday I changed my fluid, thinking that maybe my shockproof lightweight had worn out and become even thinner and this would fix it. I also added a small water/oil separator at the end of the hose in the engine bay, like someone in this thread suggested a long time ago. I though this would fix it and it would take forever to fill the separator/filter. Well, today I popped the hood to check on my filter, and...
So, after doing further research I came across this thread from '10.
https://aus300zx.com/xenforo/index.php?threads/oil-from-gearbox-vent.300868/
Very interesting. One member mentions how having a bent vent tube pointing downwards can cause this problem. I did noticed mine is bent a bit, downwards. I will bend it up a bit as soon as I get a chance, hopefully this solves my problem.
I just thought I'd share this in case anyone out there is having this problem.
I will report the results.
I still have dramas with mine, Thinking about changing oils and going away from redline lightweight, But the box feels so much nicer with redline oil in it.
I'm fairly certain I bent the tube straight a while ago and still didn't fix the issue, thats when I went to the breather setup, but I'm getting problems like yours. Was starting to think I had put the one way baffle plate in the wrong way when I rebuilt the box but think I would have bigger issues if that was the case.
Be interested to see where everyone else is at with this issue, I first thought someone mentioned a batch of lightweight shockproof that was doing this but it was not an issue with later batches but I've had a few bottles through mine by now
Mine worked a couple of years with redlige. But after one change the problems came. Changed again to a nej redline and the problem remained. Now i drive with mobil1 and havent had a single problem ?? First i bought a cheaper oil and drove a couple of miles then changed to the mobil1 just to clean the inside and get rid of the redline oil
Edited by Ajfa
Mine worked a couple of years with redlige. But after one change the problems came. Changed again to a nej redline and the problem remained. Now i drive with mobil1 and havent had a single problem [emoji1303] First i bought a cheaper oil and drove a couple of miles then changed to the mobil1 just to clean the inside and get rid of the redline oil
Which oil are you using? Im thinking of changing
A Guy here in sweden works with renovate skyline engines and gearboxes. He hates the redline oil and says it damages the gearboxes. The picture is of the redline oil
the other picture is the oil he recomended and the one i have.
Redline shockproof is a band aid for stuffed synchros, not for tracking. Or so I've read.
Depends on the viscosity, lightweight is intended for old boxes that are still ok, heavy is more for stuffed synchros and such. Or so I've read.
  • 5 weeks later...
Well, it's been over a month now since I bent my vent tube up slightly, and still having the same issue. As much as I love this blue stuff, I might have to go a different route... I was also thinking maybe the baffles inside the tranny.
I'll look into that mobile mobilubeGX. Any other recommendations?
Edited by andres14oj
 Share
    • Euros are shitboxes man. My next car going to be a Lexus or Hyundai.
    • Maybe I used the wrong sandwich plate as well. Used one piece instead of two piece.
    • Y'know what, after reading a topic on a 360kw build using a nistune (who ended up going LINK), im now considering a LINK over a nistune. The engine protection alone would probably be worth it. And id like to learn to tune so would be nice to have that safe guard. Which means i probably wont need a boost controller then, or the R35 MAF.  Becoming a bit of a blog now but oh wells. As mentioned previously, the goal is around 300kw, for a daily driver. Will be looking at fitting a highflow turbo or similar (something that doesnt require downpipes, manifolds etc to be changed out) when the current stock gives out or the money for it is there.
    • Thanks guys. Are you meant to tighten the converter bolts through the starter motor hole? Think my plate between gearbox and engine is one piece. Im heading up there tomorrow.
    • Picked my tailshaft up yesterday arv!! Test fit it and because they've gone to a ford centre bearing and CV I had to modify the mounting bracket a little bit. 5mm of each side and she went up into position and fits well. It has a 1350 uni and flange on the gearbox end so it should be plenty strong!  Got stuck in this morning and started on the wiring mess. Cut out all the wires not required that go to the body connector and cut the engine harness out. Need to go through and work out which ones I need to keep and rewire into the new ecu. Should save a small amount of weight as well. I'd love to get in and rip the dash and everything out to completely remove wiring but cbf.  Next up was the power harness for alternator, starter etc. It has a few connectors from factory that run out of it. Cut it all apart and removed what was no longer required and put some new corro and taped it all back up and bolted it all back into place.  After that I worked out where I can mount the new flex sensor. Found a couple of factory bolt holes and drilled a new hole on the bracket to suit. Need to go get a few fittings and adapters tomorrow so I can keep going.
