Hi,
Well i purchased this a few months ago, most of you would know what it is!
After some time and effort (thanks jarryd) finally got it shipped to me in Tasmania.
With the To4e setup it had, made it quite fun, laggy, but fun.
Before it got here plans had already unfolded to build a 26/30 for it.
the thought of torque and power appeals to me.heavier i know, but oh well.
before it left
mods when i got it were as follows...
Driveline:
RB20DET
RB25DET gearbox
OS Giken Twin plate & light weight flywheel
2-Way LSD
HKS T04e
HKS cast manifold
HKS 38mm external gate with screamer
Wolf 3D v4 ECU
Blitz stainless air filter
Custom stainless crossover & turbo outlet pipes
Loud in tank pump
GTR injectors
GTR intercooler
Trust Type R BOV
RSR* exhaust
Splitfire coil packs
Modified rad support housing triple core TR's radiator
Twin thermo's (tempreture controlled via ecu)
ARC oil cooler + Grex filter relocation
Sard header tank
Cusco oil breather
Suspension/Handling:
Seam welded
Apexi N1 coilovers with camber tops on front, GET in the rear
Tein castor rods
Cusco rear upper arms
Cusco rear swaybar
Rear traction rods
Welded rear strut brace
Non HICAS cradle
Alloy cradle bushes
Alloy steering spacer
5 stud conversion
Interior:
Thrash style fixed back seat
Side mount rail
Rare Abarth leather wheel
Omori Oil pressure, Omori water temp, Greddy oil temp, Blitz boost gauges in custom dash panel
Profec-A EBC
Exterior:
Missile front bar (missing lip)
Insurance DIANA skirts and rear bar
Yanack bonnet vent
Bolt-on flares smoothed over
Late model front/rear lights and grill
Stich Evolution 18x10 +18 front(+8mm spacers), 18x11 -1 rear
Falken Azenis ST115 235/40's & 245/40's with good tread
Other stuff:
Factory sunroof
Fully rebuilt tailshaft
Jap workshop & club stickers
below, some pics of when it arrived
engine bay pic
and as it sits today, engine out ready for bay to be cleaned up.
and the block
rb30 series 2 block
new welsch plugs
crack tested
boared and hoaned
new bearings
reground crank
new main seal
new water pump
new h beam conrods
arp rod bolts
cp forged pistons
cp piston rings
rb25 oil pump
so far ive got most things organised engine wise
things should start to happen over the next few weeks with engine going together etc.
i will keep you updated.
Edited by jangles
https://www.sau.com.au/forums/topic/252042-my-cefiro-build-thread/
<br />I am jealous, can only afford the 25/30 combo<br />
<br /><br /><br />
i worked it out and it isnt that much difference,
300-500 for 25 head
need upgraded springs in 25 dont in 26,
forward facing plenum on 25, 26 already has it.
plus 26 has ITB's
worked out about the same for me!
thats what i went by to justify it for myself!
Edited by jangles
awesome car - i love the styling of it and now even more with the new block going in...when mine is finished with the new motor would love to do some skids with ya - 26/30 ceffy + overfender VS 26/30 ceffy + overfender!!!
ha yeah.....good theory, but i think you might have to wait a while for me to be half good
Edited by jangles
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
