hey all
got some concerns with my ecu in my 1997 series1 RS4
ive searched through the forums for people with the same probs but cant find a definate answer
any advice would be greatly appreciated
1-its got no rev limiter,it pulls off the tacho past 9000rpm in any gear...im not too keen on a rebuild when it finally goes bang
2-the 4WD light is constantly on,from the day i bought it, it has never been off and when pushed hard enough the stag will slide when it comes on boost through corners.which is normally fun but not in a 1600kg wagon with only basic suspension mods (whiteline front swaybar)with standard height,standard shocks and springs.
the car has only had simple mods,as its a daily driver eg- pod filter,custom dump,advance front pipe 2 1/2 exhaust,gutted cat(sshhh) and its had the 100,000k service at sinergy motorsport
the guys at sinergy looked all thro the car and found no aftermarket speed/rev cut devices and also did a codes check with no results...?
numbers for the ECU are
23740 0V300
pcmnr030 c1 7327
any help and advice would be great
and whats this brown connector thing in the loom?
https://www.sau.com.au/forums/topic/260033-ecu-concerns/
http://www.skylinesaustralia.com/forums/4w...ms-t259859.html <-- for you 4WD
take it into MV automatics.
get them to hook it up to there comp, could be clutch packs or bands just not wanting to grab gear ??
in the forsale section there is a s1 autobox for sale $300
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4463844
hey all
23740 0V300
pcmnr030 c1 7327
I have the ecu (an OV300) out of my wrecked Stagea which i could post to you if you want to see what difference it makes. I want it back because i am getting another Stagea and want to send the spare ecu off to get rechipped while I am driving with the other one but if you isolate the problem(s) to the ecu it shouldn't be too hard to get another one. Let me know if you want to try it.
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4463869
Another idea: take the cover off the ecu and get as high as possible resolution photo and send it to Toshi. he will know if it has an aftermarket daughterboard but unless he recognises the handiwork he probably won't have the software to tune it...worth a try though.
ps normally you would do the back sway bar first - with just the front there would be a tendency to understeer (i.e. go straight ahead on corners).
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4463996
hi rod,
Its hard to tell but is that loom modified? The blue tape around the Black with Red stripe wire. any other things like this on the loom. If you want we could meet up and compare ecu looms even though ive got a piggyback wired in..
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4464123
thanks for the input lads,and thanks to rob (kiwirs4t) for lending me his spare ecu.and chris,yeah there is a couple of other wires that look to me like they have been cut and re-joined with electrical tape so having a quick look at yours would be a great help i think.ill be at adam's stag cruise on sunday if you want to have a chat then if your going.and ryan,my mate has a nissan consult cable from his old 300zx can you tell me whether that will plug in or not?
thanks again guys,youve all been a great help
rodney
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4468024
I asked about that exact same brown plug ages ago when I first got my Stagea thinking it had at sometime had a piggyback ecu but turns out it's normal. Also the wire that you have that is taped up you may find is the speed sensor signal wire. Mine has been spliced into for use with a Turbo timer with speed tests etc. Also had the Handbrake cable spliced into for the Turbo timer so you may find yours has been as well if there was a turbo timer installed at some time.
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4468112
rodney
I'll try to remember to bring a lappy with DataScan on the cruise - look for a Silver S1 with rego STAG34.
I agree that you need to check the 4WD issue out before you possibly break something in the xfer case...
Edited by BensDR30
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4468815
good point lachlan,but trust me,mine revs past 9000rpm.and thats why i want a limiter so that she doesnt spit out a rod.hopefully this spare ecu im waiting on will fix the problems and then all will be revealed...
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4469155
well,received the spare ecu in the post yesterday(thanks again to rob),fitted it up,and after a quick blast around the block she still has no limiter and the 4wd light is still on...after the cruise on the weekend,im 100% positive shes only RWD.im not fussed about the RWD but i do need a limiter...and after a lot of research(for and against) i think ill track down a BEE*R power builder rev limitter.there is a lot of positive opinions and a quite a few negatives on this unit but i think it will be the quickest,easiest and cheapest method of getting my limiter down to a safe RPM.and i dont want this unit to bash it all day long for the exhaust flames,just want to limit the revs.
im still open to ideas and opinion about a limiter,and is anyone running a BEE*R limiter in their stag?
thanks again for your help everyone
rodney
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4481874
get underneath and look for a front driveshaft?
Im thinking yours isnt there... definately looked rwd seeing I was behind it on sunday in the wet
also, open up the ecu (easy, just 4 screws) and take a photo of the internals plz
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4481953
rodney
There should be no need to run a rev limiter as the ecu does that. If replacing the ecu didn't help then something is wrong and needs to be tracked down and fixed. Either someone has deliberately disabled it or wiring has become damaged. An aftermarket rev limiter will be using/modifying the same signal so probably won't work. If you can borrow one i guess its worth a try but I don't think its the answer.
I got my new S1 checked out by the AA (I bought it sight unseen, 1200km away) and they said that the 4 wheel drive didn't work and the warning light stayed on. When I got the car I filled up the reservoir in the boot (it was low) and its sweet now. But I was lucky. Next stage for you is to bleed it, check that the fuses have not been pulled and yes, see if the front driveshaft is in place. Other possibilities are that some one has pulled the fuses for fun or on a dyno and stuffed the clutch packs. Have you run the Attesa diagnostic? Its on this site somewhere... someone may be able to point you to it.
BTW I have a spare Attesa ecu and the gear that sits on top of the diff.
Good luck!
Tangles its unlikely to be the ecu as the ecu I sent Rodders definitely limited the revs to about 7000 rev/min in my car. (Although having said that Rodders it would be simple to open the two ecus and compare the insides - an aftermarket daughterboard would be really obvious but I doubt theres one there since swapping the ecus made no difference).
https://www.sau.com.au/forums/topic/260033-ecu-concerns/#findComment-4482041
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
