Electronic Boost Controller
Hi,
I have this Electronic boost Controller, which I bought 3 weeks ago and have decided to sell it looks very good $300 delivered anywhere in Aus.
Here is the description.
Electronic Turbo Digital Boost Controller Black JDM
Brand New!
Features:
* Built-in turbo timer & voltage meter
* Adjustable High/Low boost setting
* Two 12V channel outputs (for nitrous, intercooler sprayer, cry02 sensor, electronic exhaust diverter)
* High performance boost controller solenoid for internal/external wastegate.
* Preset boost settings.
* Digital display screen.
* Comes with all proper accessories for a successful installation.
Applications:
* Universal Application
The electronic boost controller (BCU+) is the first boost controller to feature multiple stages of boost, an in-built turbo timer, boost gauge, voltmeter, and two 12 Volt outputs. It comes complete with a solenoid valve. This boost controller uses the latest technology to give the user multiple ways of controlling and monitoring boost levels. Providing High and Low stages of boost and adjustable gain, the boost can be tuned to switch depending on track or road conditions.
The BCU+ also incorporates an Automatic and Manual Turbo Timer to let your engine cool down after a run. By using the electrical Outputs, you can use the BCU+ to control any 12V DC source, like a nitrous kit and/or intercooler spray. Know exactly what's going on with your engine by using the Last Boost and Voltmeter settings on the easy to read LCD screen.
Multiple stages of boost (two stages)
Built in turbo timer (auto and manual)
Boost Gauge
Voltmeter
Two 12 Volt outputs
BCU+ uses the latest technology to give the user multiple ways of controlling and monitoring boost levels. With High and Low stages of boost and adjustable gain, you can tune the boost to switch depending on track or road conditions. The BCU+ also incorporates an Automatic and Manual Turbo Timer to let your engine cool down after a runb by using two electrical Outputs, you can use the BCU+ to control any 12V DC source, like a nitrous kit and/or intercooler spray. Know exactly what's going on with your engine by using the Last Boost and Voltmeter settings on the easy to read LCD screen.
The Turbo Timer has both Automatic and Manual settings. This allows the user to manually set how long the vehicle should continue to run after the key is removed from the system. Or, for an even easier setting, allow the BCU+ to calculate exactly how long your engine should run based on how much boost the engine has seen.
The Switching System is a great feature for drag racers! The BCU+ has the ability of controlling any 12v accessory based on the following criteria: Boost Level
Boost Level
Manual Timer
Automatic Timer
Limit Feature
Warn Feature
Start Boost Setting
This means you can control a nitrous system based on boost levels! This, however, is not the only option. Any electrical component, from LEDs to intercooler sprayers can be controlled by the BCU+. Please see the Optional Wiring Section of this installation manual for detailed information.
Compact Design
The BCU+ comes in a 4.17" x 4.65" x 1.1" compact design and uses on the the smallest solenoids around for an easier installation both inside the car and under the bonnet.
Information Display
The BCU+ has an LCD screen so that all the functions and settings can be viewed.
Boost Setup
Two different boost levels can be easily setup by turning the Hi and Lo knobs
Safety
The BCU+ has multiple safety features. Over boost - The LCD background display will turn red and an audible alarm will both warn the driver if over boost occurs. Limiter - The BCU+ has limiter which will limit the amount of overboost by modifying the opening of the solenoid based on the preset limited % and preset boost.
Turbo Timer
The BCU+ has a manual and automatic turbo timer. The manual timer allows the engine to run for a specified time adter the key has been removed from the ignition; and the automatic timer allows the engine to run for a certain amount of using voltage variation once the key has been removed from the ignition.
Channel Outputs
The BCU+ boost controller can be programmed to activate and deactivate electrical components when certain specified criteria are met.
Complete Kit
Vacum tube, cables and solenoid valve are all included.
Boost Gauge
Voltmeter
Two 12 Volt outputs
Boost Level
Manual Timer
Automatic Timer
Limit Feature
Warn Feature
Start Boost Setting
Compact Design
Information Display
Boost Setup
Safety
Turbo Timer
Channel Outputs
Complete Kit
  • 3 weeks later...
 Share
    • Can't forget them. Have spent the better part of the last 2 years in Bunbury. Any longer and I would have to get one of each.
    • Hit it hard last night, was in the shed till 2:30am. Had to get everything ready to try fit engine today as neighbour is going away tomorrow. This happenned today      Was going smoothly, till it wasn't. Had to lower the sway bar, remove engine mounts to get the engine to its spot and then refit everything. Head drain also created some clearance issues but got there in the end. Some idiot put the drain return on the sump virtually where the engine mount is. Hose fits on but is less than ideal, going to have to revisit it and fit a 90° fitting. Had some hiccups last night too with getting the flywheel and gearbox on. Firstly forgot the sandwich plate, so had to remove clutch and flywheel again. Then gearbox went on smoothly but then realised new block has an alignment dowel in the same spot as gearbox. GB off again to remove said dowel. Cnut. Anyway, it's in now. AC and PS pumps refitted, tail shaft bolted up as well. Left to do is reconnect all harnesses and plugs. Looks like a big mess ATM. Fit dump pipe, radiator, shifter, intake piping and associated bits, air box fill, afluids and hopefully fire it up. Looks like couriers please has lost my break in oil again. Useless pricks. Looks like I'll just get whatever mineral oil is on special at super shit auto. Hopefully it will actually run after all this or I'm going to burn it, lol.
    • The genuine ones are a minimum of $95 each on amayama. Jesse Streeter just quoted me $190 each. I can get a set of 6 MSD for $470 on ebay.
    • You forgot jet ski's and neck tatts.
    • New Monroe OESpectrum shocks for the Honda have been ordered, the car actually handles well with the OEM shocks, but from pulling the wheels off for a good inspection of the brakes and bushings, the only issue I saw was that it still has the original shocks, and with 160k km on them they are well past their use by date Also, in other "kids these days" news, the airbox resonator is "in the bin", a little more induction noise down low free reving, but it sounds really good (growly) over 4k RPM on the road, worth while silly mod for 10 minutes of work and zero dollars Also the K&N filter for the OEM airbox arrived, whilst I didn't get it for performance, as it probably doesn't give any, it's more to save a few bucks replacing OEM filters every service, 3 filter changes and it has paid for itself I also picked up another 5 litres of HPR5 for another oil filter and some more engine flush, I'll give the last HPR5 and filter change 1k km to do it's thing then flush it all out again and stick the new stuff in, anal, but I feel it's always worth the effort when I get a "new old" car to really clean out its guts, and as the K series engines have a few internal mesh filter screens for the V-Tec thingie, as well as the usual one on the oil intake tube, it's preventative maintenance to keep the oily bits happy when I'm wringing it's neck The Bogan Cruise Ship might even come out from undercover this weekend for a cruise, weather permitting of course
