Seat Queries...
I stand to be corrected, but I think R34 and R33 rails are the same - should bolt on perfectly...however, I think R33 seats are slightly larger so you may have some issued with fitment in regard to the space between the seats and the center arm rest.
what sort of rails would u need to run gtr seat in a gtt or could u just modify them.
in my s14 i put s15 seats in them and had to bend one of the rails to fit them in could u do something similar with the gtr seats as i dont really like the bride or sparco seats (im a big unit)
Edited by GUN_METAL_GTR32
Hi adrian_r34 or should I say Jess R33,
It’s quite amusing how similar the both of you are:
adrian_r34 joined 24/04/2009
Jess R33 joined 20/04/2009
Jess R33 has an Apexi Power FC with HC to sell….from her Series 1 R33 which was recently “EPA’d”
http://www.skylinesaustralia.com/forums/Po...96#entry4545796
and so do you from your recently “upgraded” Series 1 R33 to a 34gtt
http://www.skylinesaustralia.com/forums/Pa...17#entry4553917
Jess R33 was also speaking of selling her standard r33 gtst series 1 driver’s seat in the same post
and you….well…. you were quite interested in seats too….
http://www.skylinesaustralia.com/forums/Se...52#entry4554152
BUT the part that seals the deal for me is that the two of you have the same IP address…..
So….I think you need to have a little think, speak to your housemate (who you posted also has a R33)…..and let me know what you want to do…via post or PM…
What I would like is my $1200 back ASAP.
I will be contacting the police as well as DOCEP (Department of Consumer Protection) if you don’t get back to me.
Peter
Hey Guys,
Thanks for the support and advice - I'm having it looked into at the moment - so I'll let you know how it goes when it's resolved.
Cheers,
Peter
  • 1 month later...
hey.
Can someone please tell me if skylines and stageas have the same seat rails? (except for the 34 which we now all know are different :()
I just want to know if I can put 33gtr seats into a series 2 stagea and I have searched, honest, but I just can't find an exact answer. I've found bits about people putting gtr seats into stags but it doesn't say if the rails are all the same or if you need new ones.
Any advice would be greatly appreciated.
Thanks
 Share
    • Can't forget them. Have spent the better part of the last 2 years in Bunbury. Any longer and I would have to get one of each.
    • Hit it hard last night, was in the shed till 2:30am. Had to get everything ready to try fit engine today as neighbour is going away tomorrow. This happenned today      Was going smoothly, till it wasn't. Had to lower the sway bar, remove engine mounts to get the engine to its spot and then refit everything. Head drain also created some clearance issues but got there in the end. Some idiot put the drain return on the sump virtually where the engine mount is. Hose fits on but is less than ideal, going to have to revisit it and fit a 90° fitting. Had some hiccups last night too with getting the flywheel and gearbox on. Firstly forgot the sandwich plate, so had to remove clutch and flywheel again. Then gearbox went on smoothly but then realised new block has an alignment dowel in the same spot as gearbox. GB off again to remove said dowel. Cnut. Anyway, it's in now. AC and PS pumps refitted, tail shaft bolted up as well. Left to do is reconnect all harnesses and plugs. Looks like a big mess ATM. Fit dump pipe, radiator, shifter, intake piping and associated bits, air box fill, afluids and hopefully fire it up. Looks like couriers please has lost my break in oil again. Useless pricks. Looks like I'll just get whatever mineral oil is on special at super shit auto. Hopefully it will actually run after all this or I'm going to burn it, lol.
    • The genuine ones are a minimum of $95 each on amayama. Jesse Streeter just quoted me $190 each. I can get a set of 6 MSD for $470 on ebay.
    • You forgot jet ski's and neck tatts.
    • New Monroe OESpectrum shocks for the Honda have been ordered, the car actually handles well with the OEM shocks, but from pulling the wheels off for a good inspection of the brakes and bushings, the only issue I saw was that it still has the original shocks, and with 160k km on them they are well past their use by date Also, in other "kids these days" news, the airbox resonator is "in the bin", a little more induction noise down low free reving, but it sounds really good (growly) over 4k RPM on the road, worth while silly mod for 10 minutes of work and zero dollars Also the K&N filter for the OEM airbox arrived, whilst I didn't get it for performance, as it probably doesn't give any, it's more to save a few bucks replacing OEM filters every service, 3 filter changes and it has paid for itself I also picked up another 5 litres of HPR5 for another oil filter and some more engine flush, I'll give the last HPR5 and filter change 1k km to do it's thing then flush it all out again and stick the new stuff in, anal, but I feel it's always worth the effort when I get a "new old" car to really clean out its guts, and as the K series engines have a few internal mesh filter screens for the V-Tec thingie, as well as the usual one on the oil intake tube, it's preventative maintenance to keep the oily bits happy when I'm wringing it's neck The Bogan Cruise Ship might even come out from undercover this weekend for a cruise, weather permitting of course
