Jvc Dvd Headunit 2.7" Widescreen + Stereo System
KLR32R
 Share
JVC DVD Headunit with 2.7" widescreen colour monitor. JVC 6" 3-way speakers, Clarion 3" + tweaters, Soundstream 12" duel coil 300watt subwoofer in box, Singer 600 watt 2 chan amp.
Was pulled out of a car i stripped, everything was in good working order i just have no need for it. I dont have the remote for the headunit. The headunit alone is still selling for $500 second hand. I have some specs i looked up below, PM or text 0420969487 for any more info..
$600ono - pickup from Sydney
Features
The unit offers all-round A/V entertainment with a widescreen color TFT monitor neatly packed into a 1-DIN size unit. With GIGA MP3 MULTI, you can play thousands of songs burned on a DVD disc. The unit is compatible with MP3/WMA/WAV audio and DivX® and other video formats.
JVC KD-AVX11 Highlights
• Power Output: 50W x 4 Max.
• MOS-FET Power Amp
• Built-in Widescreen Monitor
• Ready for Bluetooth Adapter*
• GIGA MP3 MULTI
• WAV/MP3/WMA Compatible (DVD/CD)
• DivX®/JPEG/MPEG1,2 Compatible (DVD/CD)
• Ready for iPod**
• 108MHz/12-bit Video DAC
• 192kHz/24-bit Audio DAC
• DTS Digital Out/Dolby Digital/ MPEG Audio
• 7-Band iEQ
• J-BUS Terminal
• AV Output Terminals (Front/Rear/Subwoofer/Video)
• AV Input Terminals
• Motorized Slide-Out Face
• Shock Proof Memory
• Wall Paper Setting
• Amp Defeat Switch
• Tel. Muting
• Rear-View Camera Ready
* KS-BTA200 required, not available in some countries
** KS-PD100 required
JVC KD-AVX11 DVD/VCD Section
• DVD-R/-RW, +R/+RW, VCD Compatible
• Multi-Border DVD Compatible
• Video Format: NTSC/PAL
• Zoom (for DVD)*
• Direct Chapter/Track Access*
• Pause/Step/Slow*
• VCD Playback Control
* Remote control only
JVC KD-AVX11 Monitor Section
• 2.7-inch Wide Color TFT Monitor
• 16:9 Aspect Ratio (Selectable 4:3)
• Selectable Angle
• Aspect Select
JVC KD-AVX11 J-BUS Section
• Bluetooth Adapter (KS-BTA200, not available in some countries)
• Interface Adapter for iPod (KS-PD100)
• Digital Player Interface Adapter (KS-PD500)
• CD Changer
• Line-In Adapter (KS-U57)
• AUX-In Adapter (KS-U58)
JVC KD-AVX11 Bluetooth Wireless Technology Section*
• Hands-free Call
• Voice Recognition Dialing**
• Audio Streaming and Control
• SMS (Short Message Service) Display
• Phonebook Transfer
• Call Record List (Dialled/Received/Missed)
• Auto Answer (On/Off/Reject)
• Mic Gain Control (with Automatic Echo-canceller and Noise Reduction)
** In conjunction with voice recognition compatible mobile phone
JVC KD-AVX11 iPod Control Section*
• Play/Pause
• Skip/Search
• Random/Repeat
• Text Display
* KS-PD100 required
JVC KD-AVX11 CD Section
• CD/CD-R/CD-RW Compatible
• CD Text
• Direct Track Access*
• Random/Repeat Play
• Intro Scan
JVC KD-AVX11 Tuner Section
• HS-IV Tuner
• IF Filter
• 18 FM and 6 AM Presets
• Station Name Registration
• SSM (for FM)
• Seek (Up/Down)
• AFNS/PNC
• Stereo/Mono Switch (for FM)
• Auto Antenna
JVC KD-AVX11 Amplifier Section
• High-Pass Filter ON/OFF
• Source-Specific Volume Control
• Balance/Fader Control
• Volume Attenuator
• Max. Amp Gain Switcher
JVC KD-AVX11 General Section
• Detachable Control Panel with Carrying Case
• Beep Tone Support
• COMPU PLAY
• Power-Off Mode Eject
• Multi-Function Wireless Remote Control
• Power Switch Standby Illumination
Speakers features-
JVC CS-HX636
The new HX-series speakers deliver superior sound with smoother, flatter frequency response. This is made possible by their innovative "free edge" for midrange. "Free edge" controls excessive vibrations at low frequencies and delivers a wide frequency response with fewer peaks and dips.
240W Max. Music Power
Metal-Sputtered Olefin Cone Woofer
Aluminium Cone Midrange
PEI Balanced Dome Tweeter
Edge-Wise Would 4-Layer Voice Coil,Strontium Magnet
Edited by BLEVIT
  • 1 month later...
  • 1 month later...
 Share
    • Hold your horses, it hasn't run yet. Fingers crossed,Lol Was thinking about this the other day, could of just paid someone 10-15k and not had to touch anything. My body and hands are sore AF. I understand why people just pay, it's not an easy task to do at home and a hell of a lot of work. Wife says I should have cut my losses and got rid of it. Told her to wash her mouth out with soap.
    • That sucks about the pipe.  Life loves to bend you over sometimes.  Catch can idea seems sound to me.
    • Hi all, Enjoying learning about my new C34. Question for you experienced folks about wind noise. There seems to be a some around the A pillars. But for me, I think there's also some air leaking around the driver's window by the B pillar (e.g. right in my ear). Is this normal? It becomes significantly noticeable as you get up to 120kph. It gets louder as you add speed. The door seal is soft and in one piece. No rips or tears. The window appears to be seated properly. I am missing the external air deflector on the A pillar. Thoughts? -Kip
    • I am embarrassed by how long mine took given what you've gotten done 0_0
    • When it comes to leather seats for your R34 GTT, you might have to go the custom route. It can be a bit pricey, but the result is often worth it – tailored to your liking. Check with local upholstery shops or automotive customizing experts; they can help you design and install leather seats that match your style and preferences.
