hey all, hopeing sumone can give me some advice here, had my r33 gtst for 2 years now
and since i got it its always had a creaky clutch peddle, now iv removed the whole peldle assy inside the car,
greased it all up again and also sprayed some wd40 inside where the shaft for the master cylinder enters the unit,
it was silent! for about 2 weeks lol, from what iv gatherd. the noise is coming from that shaft on the master cylinder,
what is the best way to fix this anoying noise?
and my second question, about 1 year ago i had my stock clutch changed to an exedy sports tuff after market one, great clutch,
but since then especily when the car/box is cold, my 1st to 2nd shift is very tight and lightly crunches into 2nd, thou going from 3rd back to 2nd
its fine, every other gear change is always perfect, and as the box warms up all shifts are perfect,
im not exactly sure what gear box oil the mechanic put in the box, but im hopeing its something simple
like too thick oil used in the box or something along that line, has anyone got a sugestion on this one?
cheers, Rob.
do what most of us with gtst's do and try and let your car warm up for atleast 5 minutes before you take off, and take it easy for atleast another few minutes untill the engine has warmed up and subsequently the gear box oil chould start lubing everything after a few minutes of driving....
my prob is when the car is cold i can never put the car back into 1st without holding the clutch down for a good couple of seconds after i leave my street.... so now i roll it down the 100 meters of down hill in first, get to a t intersection, turn right out of my street, keep it in first for the 30 meters untill the main road, then i dont have the 2nd - 1st gear change prob..... after my car gets through to 3rd i guess its all lubed up and the tight gear chenges go away...
your situation would be differnt depending on time and location but really a turbo car should have time to warm up, take it easy at first, then thrash it, then give it time to cool down lol
no, most of us dont sit idleing in the driveway to warm our gtst's up. its not required, and not recommended, and doesnt warm the box up at all.
just taking it easy when you drive off till oil temps come up is the right way to go about warming it up.
but that doesnt answer the question.
all sitting in your driveway for 5 mins with the car running does is waste fuel. yes your engine will be warm but your gearbox will still be stone cold. if you drive like a grandpawhile the car is dead cold and then as it slowly comes up to temp you can slowly start to drive a bit more normal. and the engine actually takes much longer to warm up when it is sitting there idling than when being driven slowly. if your thermostat is working properly your car should be getting up to temp within 2 or 3km unless it is a very cold morning.
the squeak could be caused from a dry pivot bolt inside the gearbox. the pivot bolt is what the clutch fork pivots on. it is accessed via the rubber seal where the clutch fork goes into the box. some spray grease or silicone spray is good to use as it stays there a bit longer. anything that comes with a long nozzle is best as you can get it to the desired area.
as for the difficulty going into gear, that will be due to worn synchros and is more noticable when cold. try taking it a bit more easy or try double clutching.
the gearbox will be lubed up after a few rotations of the wheels but it will still be cold.
thanks for the responses, yea i never warm my car up, just start her up and drive it, but i never alow it to hit boost when cold, and im always very carefull with changeing gears, drive it very gently when cold, and as with the clutch squeek, iv listend to the gearbox area and its silent, the squeek is definataly not coming from there,
im thinking to try help the hard shifting ill try a different oil as yea i have no idea what my mechanic put in it, iv read that redline lightweight shockproof is really good, but as i fouind out today, really expensive, think i will try a penrite sin gearbox oil, its like 75w 85, and a bit cheaper at 45dollars for 2.5 litres, and iv only ever had great results from useinf penrite hpr10 oil, so might give it a go
use redline lightweight shockproof in there, it will fix the crunch, its not too expensive anyways, i think i payed $200 to get it changed, including the oil.
-$200 to give you a smoother gearbox doesnt sound expensive to me
but i was told by my mechanic, that when u use redline lightweight shockproof u gotta change the oil out more frequently (idk why) i think he said every 30,000 or so km's which is still a fkn long time.
Another option is VMX80.. loads cheaper than smurf's blood. Usually recommended with a dose of nulon g70 in with it.
i used VMX80 in my 33 and it didn't make a difference to any noises it had (if anything it made them worse). didn't put any nulon stuff with it though.
i think the vmx80 or 90 is what i used in my old 626's gearbox, its problem was the oposite with massive crunching downchangeing from 3rd to 2nd, but its box was really bad lol with metal shaveings constantly stuck to the drain plug, lol hope my r33's never gets that bad, cant see it happening, the vmx seemed to be a decent oil, but what is nulon g70? im geussing a cleaning agent of some sort?
and with the redline lightweight shockproof, i was at bursons looking at it last night and the bottle had a sticker on it stateing oil life time from 200'000 to 400'000 km's, and 30'000 isnt much for me, i drive my r33 a good 800kms every week, do alot of driving, need something good and that will be in there for a fair time
theres a store on ebay that sells the redline oils, ill be looking at about 130dollars for 3 litres including postage, so i dont think thats too bad
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=180285558161
thats the link
thats alright, mines been prity good, all gears are prefect, apart from especily when cold 1st to 2nd is hard and crunches, when the box is warm its not as bad, but still something i want fixed
just to shed some light on my few problems, today i changed my gearbox oil to nulon smoothshift 75w90 which is a semi synthetic oil plus about 210ml of the nulon g70,
it all feels much better, very smooth and quite, thou my 1st to 2nd shift still clunks a little into 2nd, im asumeing the syncro must be a bit damaged with that gear
and as to my clutch noise, i pulled the whole peddle assy out today, as well as the master cylinder, the creaking noise was actually coming from the shaft of the master cylinder, it wasnt moving smoothly as the clutch peddle was depressed, so the noise from that was resonating back thru the peddle and firewall creating a creaking noise in the cabin, i put some grease in and around the shaft then put the seal back over it and re asembled the car, now its quiet and very smooth like it was when i bought it, so im raped with that, hopefully it stays that way :blush:
hope this info helps someone else with the clutch noise problem
I'm a new owner of a 93 R33 Gts-t. Great car to drive with 255rwkw, but I have to use patience with the gearbox. It has a slight crunch when cold between 1st and 2nd but improves once warm and is fine for normal to moderate driving.
I took it easy when doing a track day in it though and want to find out more about the 5 speed box. Information in this post has been handy.
Does anyone know how much it would cost to get the synchros replaced, gearbox rebuilt if required?
Yeah mine was creaky, so i went spastic with rubber gloves and grease one day, fixed the prob until I got a new master cylinder fitted, think I will try silicon spray or wd40 this time to avoid having grease all over the joint. I have the same problems with cold box, just gotta persevere through it. Rev matching does help the 5th - 4th grind on the down shift though.
I am also going to try the Shockproof Lightweight when I have a spare $130, I have a 4th gear crunch which gets maddening at times! I'd prefer to get the box rebuilt or at least the synchros, but too much $$$ right now.
I only let it idle for 30 secs to get the oil up into the head - the previous owner told me that you had to let it idle until the water temp was up to 80!! (takes about 10 minutes lol) From what i've read about bores glazing etc, I prefer to just put up my street doing about 40 in 3rd gear, then through town at about the same, and just ease it onto the highway up to 100.
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
