have been advised to change to ngk v power racing plug R5671a-7
On what pretence? It's a spark plug. The air/fuel mixture doesn't look at the spark plug and think "he's running R5671a spark plugs - I think I'll generate 20kW extra". It's a spark plug - it ignites the air/fuel mixture after it receives a huge jolt of electricity. It's the same size jolt of electricity, irrespective of the type or manufacturer of the spark plug.
It really doesn't matter what number is stamped on the ceramic, as long as the plug is designed to fit the application.
You will be wasting your money, IMHO.
https://www.sau.com.au/forums/topic/272216-spark-plug/#findComment-4624080
If its the plug I'm thinking they are as cheap as the regular coppers.
I personally didn't notice any difference, if anything it felt a little less punchy but that was most likely in my head. The idea behind the plug I believe is to prevent spark blow out at high combustion pressures.
Grab a set of coppers with a heat range to suit your power and you'll be fine.
https://www.sau.com.au/forums/topic/272216-spark-plug/#findComment-4625082
is anyone out there using these in there rb
I run them in mine but the -8's and indexed.
I will be doing a dyno test back to back with mine once final tune is done to show the difference so will post up after its done :)
https://www.sau.com.au/forums/topic/272216-spark-plug/#findComment-4625181
It sounds like a cop out on behalf of the tuner. A safe rich tune is only rich at high loads, and will still be leaner than a factory setup. there is no reason to be running 12:1 afr at cruise, all it does is wreck fuel economy, catalytic converters, emmissions, cylinder bores and spark plugs
https://www.sau.com.au/forums/topic/272216-spark-plug/#findComment-4626309
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
