hey guys
im in need of some help
ok iv just bought a new sub engine harness that connects to the starter motor, alternator ect..
as the old was a bit stuffed n i through it out when my motor got taken for a rebuild.
i was looking at it today and i reliased that there no plugs on for the knock sensors, now im pretty sure the old has knock sensor plugs connected to it, but this loom seems like you got buy another small loom that connect to it for the knock sensors and a few other things
iv attated a pic of the harness i bought from rhd japan and also a pic of a knock sensor loom i found on the net for an r32gtr
now this the second loom i bought cause i thought they may have sent the wrong loom, but it wasnt and i dont really wanna go and buy a knock sensor loom if its guna be a waste of money
i would really appreciate some help please guys
sub engine harness knock sensor loom
https://www.sau.com.au/forums/topic/273016-wiring-loom-help/
According to the r32 wiring diagrams, the 2x det sensors / aac valve / & air regulator are on a sub harness, connected via an 8 pin (2x4)connector.
But... I have never pulled the motor to see, just going off the diagrams. pge 790 of 804 btw, top left corner.
Edited by heller44
that loom you got is the one that does starter, alternator, gearbox switches, battery etc lives on the chasis side.
what is the part # for the loom you have? looks like 24079-05U01 to me. If so the engine harness with knock sensors is 24077-05U21 and it lives on the engine side, and connects to the main engine loom at the rear of the fuel raill.
And if you have 2 of the wrong one....send me a price, its one of the few looms i haven't replaced yet
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
