Not cars fault, always driver's fault :)
Was only a small dink anyway, enough to spoil a day but nothing in terms of motorsport damage :)
I think that's what caught alot of people off guard Nick - the sharp turn straight after the hill on mini wang. Too much speed and you ended up snap oversteering or slamming on the brakes and going straight into the cones ;)
nah this is motorsport, never the drivers fault :(:)
gotta watch the surface on the mini wang, lots of gravel makes it really tricky... I'm new to ABS and last time I was there I failed to stop in the garage... twice :P
you gotta hold it flat over the hill on the mini wang otherwise your just not trying hard enough! lol
aaah... I hate missing deca
  • Replies 358
yeah me too!
By the looks of your sig you're back in action. You better be there in Nov. What about haunted hills?
yep but I've blown the motorsport budget for this year... so unless you can guarantee my wife I won't break my car I won't be there:(
I was thinking for the next deca I might offer to pay someones fuel/entry/accom for a drive of their car... might get one of the young blokes interested who are on a tight budget
We are planning a big trip next year so that's taking priority... looking at these threads doesn't make it easy though
yep but I've blown the motorsport budget for this year... so unless you can guarantee my wife I won't break my car I won't be there:down:
Hahahaha, your the last bloke that would want to be making that sort of guarantee.
Oh, Monday, the car sounded tops under the freeway.
How you drive largely determines that, so can YOU gaurantee your wife you will stay away from the limiter this time? :down:
If you are looking after it and it still fails then whatever it was that died was going to fail anyway, better at DECA than at Targa or something where you have paid a bomb to be there.
If you're flogging the guts out of it incessantly though then it's just a matter of time before something goes.
Come to DECA, don't drive beyond the limits of the car and you should be fine.
Also, give me a ride when you come in November :/
My one complaint about DECA was the unnecessarily high RPM launches some people made during the timed events...nothing but wheelspin for 15 metres = shit launch! And people sitting on the limiter on the skidpan, seemingly forgetting they have a clutch and a gearbox :down:
lol... ummmmm... yeah... I've never really been good at the whole 'sensible' thing... I'll leave that to 50yr old Porsche drivers... its a skidpan afterall... sure you can try to be 'fast' but failing that its just fun to be a bit stupid... I'm an expert at stupid :/
plus I actually like being married and aren't really ready for divorce yet... sad I know
Hightower: I was hoping it would throw a flame for you, best way to waste petrol... ever :down:
Bahaha, I've only just got a handle on this sensible thing in recent times (I even moved to driving an NA auto as a daily) so I hear ya.
You've picked my weakness - FLAMES!
DECA needs more flamige! If my cat wasn't so pretty I'd gut it... guess it's time for a decat pipe and some adjustments to the mix :P
Well some cars need the revs to make power. Also small amount of wheelspin generates heat which can help.
What's wrong with limiters haha.
Can anyone comment on how I was driving, with regards to treatment of the car and stupid launches (if anyone was paying attention)?
I know I hit the limiter quite a bit but that wasn't on purpose, I was so focused on the track that the limiter was usually the first signal that I needed to shift.
I'm not overly worried as I've heard NA 2JZ's are near impossible to pop, but then again I really can't afford anything major to go wrong either.
Thanks Russ, this is so true, without high RPM i find it very hard to get off the line without bogging down. Limiter is a very easy option to get off the line
My one complaint about DECA was the unnecessarily high RPM launches some people made during the timed events...nothing but wheelspin for 15 metres = shit launch! And people sitting on the limiter on the skidpan, seemingly forgetting they have a clutch and a gearbox :)
I try to stay in gear 1 through the track cause if im in 2nd and pull the handbrake around a turn i just get bogged down and waste time shifting into first.
My gearbox isnt too healthy and grinding it into 1st gear at high revs can only lead to troubles
Engine+tune is more than happy to bounce off the limiter :P
Engine+tune is more than happy to bounce off the limiter :)
I wonder if that's why Chris (guy in the white automatic Evo) did so well. He could just slap the triptronic this way and that regardless of the revs.
Probably more to do with the fact he was in an Evo. :P
Next time you're at the skidpan try and change into 1st while the car is sliding. I do it all the time around cones.
Grab the handbrake and as the rear wheels are not spinning fast selecting 1st gear is easy. Don't need to force it.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
