I've just bought my first r32 skyline gtr. The car has had a new engine and the standard boost gauge and apexi boost gauge have not been connected. There's 2 vacuum lines in the engine bay one that I think is for the standard gauge which is connected to some sort of sensor on the drivers side firewall. It t's off 3 ways one way to the sensor one heading into the cabin and the other to nothing. I've had my radio and climate controls out to connect a radar detector and there is also a vacuum line behind there not connected to anything which I think is the one coming from the engine.
The vacuum line for the Apexi gauge is just sat in the engine bay not connected. It has what looks like a one way valve in line.
Any ideas where I can can connect at least one of these up?
https://www.sau.com.au/forums/topic/288316-boost-gauge-installation/
You can tap of it from where your standard boost line. Just go supercheap auto and buy the 3 way connecter its the little plastic thingy. But if you want it like FULLy accurate, Connect it directly to the standard line or you can either go to the fuel line vacum.
The standard one isn't connected to anything. When you say the fuel line vacuum do you mean the short piece that goes on the fuel pressure regulator?
the standard one connects to a little black box on the left hand side of the firewall near the booster
i would also t-piece of that
yeah its already connected to that black box but its not connected to the engine so not picking any vacuum up. Need to know where on the engine to connect.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
