hey guys can anyone tell me how to install manual boost controler on a r32 gts-t,
i can only find the r33 diy and i cant seem to find the solinoide on the r32
and also wat is the maximum boost i should run with the stock smic and basically stock engine bay?
any help will be apreciated
cheers gsep
where you put the controller on a 32 is the same as on a 33, just ignore any reference to the solenoid. there will be a hose from the cooler piping to the wastegate actuator and that's where you put the controller.
what exhaust, etc are you running? that is going to be the biggest factor. if you are running stock exhaust then i wouldn't raise the boost much at all, maybe 1 psi. since we are coming into the hotter months i wouldn't be going too much higher on the stock cooler either. if you don't drive it hard then you can get away with higher boost, but if you regularly give it the beans then i would be thinking about going a fmic as the stock cooler does suffer from heat soak rather quickly
