hey,
im after a good quality set of injectors and coil packs for my R33 gtst,
its all pretty much stock, just got a atmo BOV, thats about it...
so if anyone could point me in the right direction it would be nice. Oh btw im from perth, so if you know a shop in perth would be handy to, or ill get them off the net :P
cheers
https://www.sau.com.au/forums/topic/298305-coil-packs-injectors/
are you wanting bigger injectors or just replacement stock ones? if going bigger then don't forget you need some sort of aftermarket engine management to run the bigger injectors.
also look online for coil packs. they will be cheaper.
im just after some replacements for my stocks :nyaanyaa: haha yeh im looking on ebay they fairly cheap there. do i have to get certain spark plugs or anything, was looking at splitfires :P sounds nice and sexy to me :) haha
Take it to a workshop in your state who knows what they're doing.
You need an aftermarket ECU to run non-standard injectors (don't even bother with 2nd hand items, again asking for trouble, if the current injectors work just get them ultrasonically cleaned instead), and a tune to match the bigger injectors.
Atmo BOV on a stock ECU is asking for trouble, and could be the problem.
Gap current plugs down to 0.8mm, Check the ignitor ground wire (if it's only misfiring when hot you might need a new ignitor), try a new set of copper plugs (if still misfires gap them down to 0.8mm), then have a look at replacing your coilpacks (check http://www.performance-wise.com/page63.htm for cheaper yellowjacket coils)
good aftermarket ecu would be a Z32 ecu with a nistune board in it. also the best bang for your buck option. will set you back around $1000
as for injectors, i agree with just getting the stock ones cleaned professionally.
as for spark plugs, BCPR6ES would be my recommendation. try new plugs before going new coils. much cheaper and can sometimes solve missfire issues if they are simply caused by worn plugs.
i got new spark plugs, didnt really help, just made my car start to shudder at idel... not sure if its ment to or no, made it stop hunting as much ;) so i guess ill go out and get some coil packs to see whats the go, i brought some injector cleaner to see if thats any good.. if not ill take it to someone to clean them xD
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
