1996 RS4 stagea series 1 MANUAL!
car is located in warwick qld bout 2hrs from brissy
my phone number is 0439665645 i would prefer sms's.... pm me or on write on this thread
more pics by request
Under the bonnet
  • Just had rebulid 3750kms ago (receipt to prove)
  • Always warmed up to operating temp before taken over 3,000 rpm
  • Always cooled down
  • running castrol edge oils last changed at the same times as plugs (250kms ago)
  • full 3inch mandrel bent system hiflow cat hotdog and cannon
  • just replaced the old gt35r(due to worn out bearings) new turbo has a .63 rear with polished housing
  • greddy style inlet plenum painted in marble
  • splitfire coilpacks with new plugs (replaced 250kms ago)
  • alloy cooler pipes with new silicon joiners and new clamps
  • 14' thermo fan (running off turbo timer)
  • new vaccum lines from the plenum
  • turbosmart dualstage boost controller
  • 600by300by75 cooler
  • brand new half size hi performance century battery
  • original stagea rs4 strut brace
  • greddy/trust style bov (currently not fitted)
  • haltech e11v2 - external 3bar map
  • tial external wastegate (with screamer)
  • himount stainless manifold
  • s15injectors... 480cc
  • 500hp walbro intank pump
  • drift catch can
  • gates blue radiator hoses
  • abs etc all the fancy stuff they came out with from factory
  • kn pod filter
  • haltech removes the afm and 02 sensor, but will go with the car including the original plenum and injectors
  • manual conversion with heavy clutch (unsure of what exactly)
  • sard pressure reg
Interior
  • jvc indash dvd player 7inch screen (double din) touch screen etc etc
  • 10inch roof mount screen with built in dvd player and av sockets with led interior lights
  • pioneer 6inch speakers in the 4 doors
  • soundstream trantula series 6.5 inch speakers in the tailgate(hatch)
  • 4 channel amp (running sub and 6.5s)
  • crossfire single 12inch sub in sealed box
  • new floor mats
  • stagea cargo mat and floor mat for tailshaft tunnel in the back
  • reclining rear seats (folding foward also)
  • electric front seats
  • interior is black leather
  • climate control
  • splitfire boost and voltmeter guages
  • superclean trim always kept tidy and maintained
  • powerinvertor also (plug in the playstation etc)
  • trust gearknob
  • factory tint in mint condition
  • pencil type turbo timer digital led
Suspension and exterior
  • bilstein front struts
  • kyb rear struts with kingsprings
  • 20inch daat d69 rims with removeable plastic insert(paintable etc)
  • brand new tyres (hardly driven on)
  • factory green metallic paint in vgc
  • also comes with 16inch 5spokes (factory type wheel) with unroadworthy tyres
  • Also i have rs4stg plate for nsw buyers if interested
since owning the car i have spent many thousand of dollars to get it where i am happy with it, altho there is still a few minor problems such as -
  • needs new exhaust manifold gasket (i have a brand new one ready to be put on)
  • a/c need gas
  • need new dump pipe flange (which i will be replacing as soon as i put the new manifold gasket on)
the stagea is currently running 14psi (no wear near its potential) so after the new dump pipe and gasket goes on i will be getting it tuned, the workshop beleives it will make approx 400hp at all 4s
Previously before the plenum, fuel system, and new turbo was fitted the stagea made 260kw at all 4s on 18psi... i have tryed to list everything but there could be some things i may have missed out on
i want $19,000 as it sits, which is only a fraction of what it owes/cost me and seems more than reasonable considering the price of other stageas i have seen... considering how good of condition it is in being manual and all the extras... i maybe able to remove parts to lower the price if required (such as rims, headunit, boost controller etc)
Im very open to swap offers looking at everything really just wanting a change, can also be view on boostcruising and will be on car sales shortly
Edited by lockie_003
https://www.sau.com.au/forums/topic/302067-manual-series-1-rs4-stagea/
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
