Hey guys,
Are rb20det's really slow or is it just me? I recently got a r32 gts4 converted to RWD,
Stock turbo
Stock airbox
No cat
11psi boost
Stock zorst
At about 2500 it starts getting up to 11psi which holds till about 6000 then trails down to about 9..
My issue is, it only seems to give you that 'turbocharged boost' feeling at about 3-3500 then the rest of the gear feels like a NA despite the bost guage reading 11.
After doing a lot of searching on these forums most people complain about no low end but good top end, where i seem to be the opposite..
I used to have a SR20det silvia which was slow in low revs then kept getting faster as the revs climbed higher which is the feeling i like/expect from a turbo car
Any ideas? I could be paranoid and just have a slow 6 cylinder 20det.
Cheers
https://www.sau.com.au/forums/topic/324324-i-only-have-low-mid-range-power/
Sounds about right for a stock RB20 turbo.
Source yourself an RB25 turbo (preferably a series 1) and wind it up to 12psi.. you will lose some low down but gain a fair bit in the top end and it will pull all the way to redline.
thats not the feeling i last had from a rb20det with just a catback. as per results last I drove one felt like it had plenty up top and a little lacking down low, the rb25 turbo added to this in both departments.
sounds to me like you are missing your top end action. how long have you owned the car? was it like this from day one?
things to test: fuel reg & fuel pump.
suggested test: crimp the return hose off the reg, see if it does anything. this is to be done for TEST sake only and is TEMPORARY. I wouldnt run the car like that for long.
$10 says its ur reg
$10 says its ur reg
I've had the car about a week so yeah it's always been like this. At first i just assumed the rb20det is slow but after a bit more driving i decided it's definately lacking top end.
In your test you say 'see if it does anything', what should i be looking for here?
Thanks for the replies
$10 says its ur reg
His doesn't even have a catback..
And when my stock fuel pump was dying, it was actually leaning the engine out and making it go harder.
It's been so long since I had an RB20 with a stock turbo so it's hard to remember back that far but, I'm sure it came on a lot earlier than 3500 (that's when the 25 turbo was pulling hard).
The pulling feeling in my car is around 3000 im not entirely sure but the point of my post is that that pulling feeling dissappears soon after and the rest of the gear feels like an NA Rb25 if you like.
I'll try the fuel reg thing anyway and let you guys know how it goes tomorrow arvo.
you have a stock exhaust. that will be restricting things in the top end. the cat may also be a bit blocked make it even more sluggish in the top end.
I think he said he doesn't have a cat.
How many km has the engine done? has the timing belt been done? (thinking it may have slipped a tooth or two?)
But yeah, the stock exhaust won't be doing you any favours.. get a full 3" turbo back.
And find someone in your area with another stocker and compare.
Yep i cant do that mate no boost controller, it's boosting at 11psi becuase i have no cat
Doesn't matter if you have a boost controller or not, the stock RB20 actuator is ~10psi, the only way you could go lower is with an R33/34 actuator which is ~5psi but that's just stupid.
My stock ECU handled 14psi with the stock turbo and 12psi with the RB25 turbo.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
