FS - epox motherboard 8rda+
muck
 Share
asking $60.
motherboard is still in computer, and in 100% working condition, its less than a year old.
upgrading my system to something faster.
may still have the receipts... im not too sure.. havent had a good look. bought from cpl in melbourne.
specs shown :-
CPU
Socket A for AMD Athlon/XP/Duron
Chipset
Northbridge: NVIDIA nForce2 SPP
Southbridge: MCP-T
FSB
200/266/333/400Mhz
Form Factor
ATX form factor, (30.5 x 24.5 cm)
Bus Speeds
100 - 250MHz
Memory
3 x 184-pin DDR DIMM Slots Up to 3GB
Dual Channel PC1600/2100/2700/3200
Multiplier
Nil
Voltages
VCore up to 2.2V
VMem 2.5 - 2.9V
VAGP 1.5 - 1.9V
Expansion Slots
1 AGP Slot
6 PCI Slots
Fan Connectors
3 (1 CPU, 2 Chassis)
Onboard IDE/SCSI
Dual channel bus master IDE supporting up to 4 IDE devices ATA/133/100/66/
Integrated Components
Realtek ALC650 6 Channel Audio
Realtek RTL8201BL 10/100MB LAN
Realtek RTL8801B IEEE1394a
 Share
    • Because it's rubbish, it got progressively better with each generation but still rubbish when you're pushing the car on the track. Some like it, most hate it.
    • Yeah, I presumed that the pic was of some other car, because of the F. Ikeya arms.
    • Did a little bit this afternoon and pulled the dump and turbo off so I could take the mani off to clean it up and give it a few coats of paint. Wire wheeled what I could get to and then got the sand paper out to get the tight spots. Gave it one coat so far, will do another two tomorrow and see if I can fit it in the oven to bake it for an hour along with the adapter and dbw.  Hoping the exhaust wrap I ordered turns up soon so I can wrap the dump and screamer. Ordered 30M so I'll wrap back as far as I can to help a little with temp next to the box and also the floorpan.
    • Yeah I think overall I’m running the expected power I should be running for now and I’ll just enjoy it for the time being until I get some other parts. Thanks for the advice mate I appreciate it!
    • That's fair enough.  Might be time to just enjoy what you have until you sort the ecu/flex sensor situation. You can pretty much guarantee that you are knock limited and e85 is going to be the solution to more power.
