RB20 AFM pleeeease
druzilla32
 Share
hey guys, i know i posted this in the wanted section, but i think il get more response here.
I need a WORKING RB20 afm asap, i cant realy drive my car until i get one. :)
the car will stall and idle at 1700rpm etc.
how much could i pick one up for?
thanks guys..
You probs could fix the afm. All you need to do is cut the sealing rubber on the top of the afm and remove the plastic cover. Inside is some little tabs that are soldered to the pins in that connect the afm to the plug. These tabs get a little brittal and get bad connections. Just resolder these points and all should be good. This is the most common thing for afm on nissans to die. I fixed my mates z32 afm doing the same thing.
If that don't fix it then yes get another one.
 Share
