Hi there, only just driving this car 3rd day and decided to stretch its legs along the highway after needing to overtake, dropped it back to 2nd at about 80kph to let see how far i could stretch it, and it did not like it at all, felt like the auto was jumping in and out of gear, and car surged back and forth until i dropped it back into drive and gently accelerated past, i have heard this is not a new issue with stagea's.
Any heads up information would be great, ill check back in tonight after work, sort of sposed to be working right now :)
Thanks in advance:)
https://www.sau.com.au/forums/topic/333162-stagea-c34-automatic-surging/
Hi mate,
The auto box's in these big heavy cars need some good TLC once they are landed here in aus. A auto trans service with new fluids and tightening the bands will help but your best bet would be to get a shift kit installed while they are in their. Series 1 or 2? What state are you in?
I just did a significant mod. Make sure you have NO splits in any of your vacuum/pressure hoses. Make sure you are not over boosting. You can get a fuel cut or your AFM can be shit or your O2 sensor UTS.
Welcome to Boost World.
Hi mate,
Thinking a full service might be the trick, located mid north coast of new south wales, coffs harbour area.
Dont think its overboosting? but alas no boost gauge to check either, i did own a 180sx prior to this so is not first turbo, been a booster for awhile now.
I have heard of shift kits for the stageas in a few readups, looks might i might just have to take it in and spend some coin, now just need to find some coin:)
Just cruising its a magnificent car to drive, also where the hell is the auto trans fluid dipstick, i feel like a right tool but i honestly cannot see it in the engine bay!
Thanks again for quick replies guys.
Hi had the same problem with my sons RS4, have a look at all the hoses feeding the wastegate , you can back it in that one is split somewhere and you have blown it off.
Ill start checking each and every hose/vacuum line first light tomorrow, if thats all the problem is, i will be ecstatically happy, saves me doing a full service immediately. Should be a relatively cheap repair if thats the case.
I have always looked at stageas and thought "mm yeah, they are ok..but naaah" but been more of a 2door coupe man (180's, R33's)
But i tell you what, this stagea, even currently with its issue has stolen my heart.
Talk about a well designed car, this thing is just amazing.
All i have to do now is remind myself i have backdoors, and stop trying to pile into the front seat with my hands full, only to lob all my bags etc over onto back seat, and realise there is a door there.
I will do a full checkover tomorrow and report back, delighted to see there is dedicated Stagea owners to help me through it, very helpful guys, thanks again.
Auto trans dipstick is a tricky bugger!
Its in between the firewall and engine slightly towards the drivers side :ermm:
Ah many thanks, ill find that tomorrow aswell, btw i believe series 1? its 1998 model if that helps.
Unsure how to tell, i can take some pics if required?
if its a tiptronic auto its a series 2. the other main difference is the S2 has separate hi-beam lights to the main head lamps, S1's are part of the same fitting. can you post up a bit of list of mods you have if any? to me it appears your problem is related to a maxed out air flow meter or the over boost protection that the S2's have, but you usually only start seeing those problems emerging after doing a few mods.
Not being a C34 owner, I don't how useful this will be, but if these use an encoder style speed sensor in the gearbox, (rather than a cable drive set up) it may be the culprit. On most Nissan gearboxes the speedo drive points down, and if the lip seal in the drive goes, atf can leak down the speedo drive shaft and into the encoder.
I had an auto R31 wagon that exhibited the same symptoms as the encoder filled with atf and slowly died. I know the next question, the speedo needle never even flickered, to begin with, but as the sensor
Sorry about that, posting from my phone, ran out of room.
Anyway, as the sensor died, it became easier to diagnose. At a steady cruise, it would flick in & out of O/D as the gearbox lost the speed signal. The speed sensor (if it has one) is situated on the underside of the box near the gearbox mount, a black round item with 3 wire coming out of it. Unplug it, it easily screws out, leaving the drive mechanism in the gearbox. If it has atf in it, this MAY be your issue. The lip seal costs about $2 and takes about 20 mins to change, don't know about the speed sensor cost. As I say, not being a C34 owner, this may be of no use, just something to check.
if the car is having trouble selecting and staying in gear its going to be the gearbox in need of some tlc.
Under high load say going up a hill with a fair bit of throttle does it sort of feel like its slipping and not giving forward momentum at times?'
On my 35km daily trip to work its all up and down hills, it doesnt seem to struggle at all :action-smiley-069: just when i try to put my foot down it has an arguement with me, anything (at a guess) up to 50% acceleration it seems to be fine with, ill need to drive it more to be more precise.
Heres a doozy for you, checked ATF this morning, unless the dipstick is lying to me, it is saying there is almost twice as much fluid in the box then there should be, i checked it 3 times with same reading with cold engine. ill do another check in town with engine hot as im having a mate who is more engine friendly then myself investigate if i have any split hoses. :)
Mods list: Coilovers.
Yup thats it! :action-smiley-069: has a side mount FMIC but i believe thats factory?
Update: Cannot see any busted lines, or leaking lines. then again my mate decided for once in his life to leave his house before 10am and i did not catch up with him. I will still get him to check over it again yet.
Now for the interesting find..
:) There was about 400ml of water chilling out in my airbox like a swimming pool :)
I decided one checking the condition of the air filter after reading QWK32's post as i figured it could be something relative to an AFM issue, i did have that occur in the 180sx i previously owned and it was a similiar reaction to what happened to me on the HWY yesterday
Much to my horror i discovered approx 400ml of water staring back at me in the airbox, initially i thought it was oil and almost cried on the spot.
But no i assure you all its pure H20, well was anyway, i absorbed that sucker out into about 8 sheets of absorbant paper
I have just taken it for 4 runs up and down my main HWY, 60>130, 0>100, 80 dropped to 2nd> 120, all close to full throttle with no issues what so ever.
Could this have been all it was? i did also give the air filter a vigorous cleaning, wasnt overly bad to start with, 1 dragon fly, 1 stick inspect and random particles being the main suspects :D
Im still suspicious that there is more to happen to the problem, and the ATF level is still a concern, but currently the car is behaving 100%.
I'll keep you all posted, Many thanks again everyone :action-smiley-069:
sounds like the water could have been the problem, did it look like water was getting sucked through the air filter element, ie, was the element damp? if so your probably lucky the AFM didn't die because of it. the reading on the auto dipstick might not have been an accurate one, i know it takes me about 5 attempts to get a good level reading on them, try sliding it out at different rotations/angle to make sure it isn't rubbing up against the wall of the tube.
No the air filter itself was bone dry, its really quite baffling, but there was a substancial amount of water in the bottom of the airbox, unknown as to how it got there, it has all been removed, being on country roads and having coilovers, ide say some of it was being sucked up through the turbo and causing my problem, it has not happened at all today, ive done about 120km in total flawlessly.
The Stagea was detailed previously to me getting it, perhaps a pressure hose was angled through the grill and spurted it up through airbox, thats my only possible idea so far. :P
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
