What the japs are really doing? we do not know... I would love to go there personally to check it out.
We have at least two top Japanese tuners in Auckland including one (Soichi from ST HiTec) to whom people bring RBs from all over NZ for a tune but I guess Japan is closer than Auckland for you at the moment!
so does he go with the leaner tune an less timing or rich ?
And as someone else said would be good to see some fc or other maps of aggresive tunes !
HKS , APEX , MINS , TRIAL , all famous shop race cars AFR 10.8 at before cat (around same place std O2 sensor).
They are try to 0-300km/h at YATABE also 0-1000m race in 1990s then they found best AFR 10.8.
AFR 11.3 some time engine blow but 10.8 never engine blow.(around 800hp RB engine )
Std R33 25det AFR around 10 also std IMPREZA AFR around 9.5.
So AFR 10.8 is not rich.
I think AFR 12 at muffler is not problem for street car.(FMIC , full exhoust , boost 12-13psi)
But bigger turbo car need richer than AFR12.(Im adjusting AFR 11-11.5 at muffler.This is around 10.8-11.3 at before cat)
Thanks Toshi, I never knew there was a difference between AFR at muffler and AFR before cat. I have just installed an AFR sensor before the cat. I'll have to keep that in mind...
of course there is thats the whole purpose of the cat.
It's an interesting topic, been watching this space for a while and I was hoping for Sydney's top Japanese tuner to respond to this..
it is good to get some insight about this from Toshi
seems like the tuning method between Japanese tuners and Australians are not too different after all, its just the mail order tunes that are richer for margin of safety
Hey guys,
Just want to add a couple more things here.
Basically, when AFR is rich, piston and cylinder can simply cool down by fuel.
So if you drive stock R33 at the race circuit for 12 hours, it will never blow the engine.
Just for extra information, when Factory Subaru liberty turbo (all stock) made the fastest record (faster than Saab turbo) in 0-100000km in oval circuit at 1989 year (maybe 1988), its AFR was 9.5. If it actually was AFR12, it probably couldn't have completed the circuit.
Factory tune is to be safe but I do know that the Japanese tuners do shave the margin a bit resulting in AFR10.8 at before cat.
The other thing is, adjusting AFR to 12 in summer, it wouldn't be too suitable for winter.
In winter AFR will end up around 13 and i'd say it not too safe on a race circuit.
I hope I was convincing enough.
Just to finish off, I think it'd probably be better in the long run to tell the tuners what exactly you're after; better fuel consumption or higher power and where you'd be using the car. street or circuit because these will all be important factors.
rich - haven't got a map - can't afford him atm!!
With a name like Toshi I'm guessing you are a Jap tuner??? :cool:
I for one dont mind running my car from 12.0 coming into boost and dropping gradually to 11.0 say from about 6000 up(ie. before the cat).....That way fuel consumption would not be that bad and the extra fuel will be there to protect the engine higher up in the rev range
Is there some thing i am not getting????.....
Is there sooo much power to be gained by leaning out the afr from 11.0 to 12.0 on pump??? or is it that skyline owners are so cheap they cant afford to keep on filling up the juice so they go complaining to their tuners that their fuel consumption has gone out the window after he has raised the boost a couple of psi and retuned the ecu so now its up to him to get more power out of the car BUT maintain its factory consumption rate???
Again i know which way i'd rather have it.....
i think most workshops doing a dyno tune on a car would do it with an 02 sensor up the muffler
this saves time and is quicker and easier to perform
how many workshops would remove the factory 02 sensor and put a wideband sensor in the bung on the dump for tuning and then remove it when done ?
its old school tuning for rich.... even the newer factory euro turbo cars are tuned fairly lean... ie leaner than 12.5... not that we go there often... customer and car determine the tune really.
I've seen perfectly good results from 13:1 and around 500hp on an endurance race car.
My tuner (Scots not Japanese) gets all his customers to put a second bung in the dump for the wideband.
If youre going to bother putting the bung in, may as well just install the wideband in the dash... Much more practical than climbing under the car and installing it each time.
There isnt much difference in readings from dump to muffler from what I have seen. Perhaps there would be on a stock cat?
It can change slightly from downpipe to tailpipe.
Here is a dyno sheet of a car i tuned here, because this car was from a different country and their fuel is not as good as ours I richend it up on the top end. (different altitude also) the higher you go the richer you go, so at home his car is running around 11afr
You can actually see the power raise start to drop exactly where the AFR richens up .5 or less of a AFR
I have a saying, Keep em rich keep em cool. A cool engine is not going to melt unless something is very very wrong.
"skyline owners so cheap because they would rather run 12's to save fuel" what a ridiculous statement. 1 afr on boost will make no difference in fuel economy. Do you drive wide open throttle to work in the morning? if so I hope you don't live near my family.
I always ask for AFR 11.5 when I go to get a tune. It always comes out at 12.0 or higher. No idea why tuners insist on running leaner for a few percent power and end up with higher temps if you ever use it on the track or highway.
what the main reason behind richening it up after what i assume is peak torque?
im guessing just to cool it down a little?
do you add more timing in during the enrichment after 6500RPM
from what I've read to keep the pistons cool, the quicker than move about the more friction & heat it will cause right?
richening up the tune up the top will keep the pistons/rings/ring lands in tack but this sacrifices power output.
and from what toshi has said before and after cat, yes there is a difference, I've had my car on a dyno and the A/Fs were different to what my wideband was reading (pre cat).
Most tuners are save time/money by tuning at the exhaust tip, but I don't believe that's the best way to do it.
I personally have pumped in extra timing after MBT, for my old setup it was around 5600rpm, and the timing for row 17 read something like
Row vs Timing 10/13 11/13 12/13 14/13 15/14 16/14 17/15 18/11 19/11 20/11
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
