Hey all, im just wondering if our sump and diff (c34 awd) is the same as the rb26 sump and diff???
im thinking of forging the bottom end rb26 i have and popping on my rb25neo head.
some things i just havent figured out yet, will the rb25 NEO head fit on the rb26 block??? i know the r33 one will fit.
i would just forge my rb25neo engine, but all i find is the r33 rb25 pistons and i dont know if they fit or not.
so its either forging the rb26 with 25 head or forging my full rb25 NEO.
anyone have any clues???
all help is greatly appreciated.
p.s i have the r33 manual, but its only got the non neo rb25 motor in it. so i cant go off that for the NEO motor
https://www.sau.com.au/forums/topic/345891-rb2526-build-up/
i have found the piston differences between the rb25 neo and rb25 from the r33.
the r33 head works with the rb26 block while the rb25neo technically shouldnt.... i think.
the r33 rb25 pistons are close to identical to the rb26 pistons, and the rb25 neo pistons have the valve guides cut in
this is a rb25neo engine:
this is a rb25 r33 engine:
and this is rb26 enigne:
so technically does it mean that the valves would hit the piston if you were to use a r33 piston in a neo motor???
the Neo piston just seems to look like it has more meat around the sides, while the r33 ones have just a flat cut.... if that makes sense.
is that why the neo motor only has 51cc combustion chamber?
p.s just found out that the rb25 neo engine has a higher lift than the r33 one hence why the valve reliefs.
plus i think the r33 has larger valves than the NEO
i think im very very slowly answering my own questions here :S
Edited by Bronx
https://www.sau.com.au/forums/topic/345891-rb2526-build-up/#findComment-5570608
Are you looking to use RB26 internals including crank, rods and oversized pistons to get it to 2.7. RB25 and RB26 has the same bore but its the stroke that gives it the extra 100cc. Much cheaper option than a stroker kit. You will need to use a quality adaptor plate. RB26 has RB25 sump bolt pattern also. I was talking with chuckie and horrace regarding this the other day. Will make the RB30 purists mad. Eat shit. lol
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/345891-rb2526-build-up/#findComment-5570747
You are looking to use RB26 internals including crank, rods and oversized pistons to get it to 2.7. RB25 and RB26 has the same bore but its the stroke that gives it the extra 100cc. Much cheaper option than a stroker kit. You will need to use a quality adaptor plate. RB26 has RB25 sump bolt pattern also. I was talking with chuckie and horrace regarding this the other day. Will make the RB30 purists mad. Eat shit. lol
Would be easier to forge your Neo
https://www.sau.com.au/forums/topic/345891-rb2526-build-up/#findComment-5570799
Umm, forged with this 2.7l setup? depends on how much to spend. You gotta luv the word "easier" lol
I think the scope is to raise displacement and strenghten the engine. Funny what will fit. Gotta like nissans.
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/345891-rb2526-build-up/#findComment-5570812
Due to the Neo having a smaller combustion chamber of 52-56cc and a R33 Rb35 and Rb26 having approx 62-68cc, you will need to use custom made pistons to get the compression down, otherwise it will be approx 10.5:1
If you use Rb26 crank you have to use rb26 pistons due to the pin height of 30.3mm. Rb25 is 32mm.
Other wise pistons will come up too high out of the block
https://www.sau.com.au/forums/topic/345891-rb2526-build-up/#findComment-5570946
LOL that's just it nothing will work without custom pistons stay 2.5 to get close to 2.7 would cost more than it's worth.
https://www.sau.com.au/forums/topic/345891-rb2526-build-up/#findComment-5571674
Not more than a stroker kit and only if you dont use the RB26 crank will you run into issues. You can use RB26 pistons or there are a number of places that do custom jobbies at about the same price as forged arias or acl. I didnt say it was the easiest way to raise capacity, but it can be done. Not many ppl do 25/26 builds so it sorta narrows the options down. Each to there own i suppose.
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/345891-rb2526-build-up/#findComment-5571697
stupid NEO enigne, make life so hard. maybe i should just rebuild the rb26 head i have. might work better, but i just dont have the little attatchemtn parts for the engine, like aac valve, ignition module and vct. nor do i have cam covers :)
its just so dirt cheap to get pistons and rods for the rb26, i bought a set for my mate and he paid 1200 incl shipping for the full set. and i just cant find a NEO set.
p.s how the F%^$ do you change the forum layout so you dont have to click on the replies to read them!!!!!!!!!!!!!!
found out how to change it :whistling::D:D:D:D:D
Edited by Bronx
https://www.sau.com.au/forums/topic/345891-rb2526-build-up/#findComment-5571793
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
