hey guys im looking at different options for my vl with a rb25. i was thinking of getting custom made intercooler piping
however if i was to get a rb25 kit and modify pieces of it what would you guys think i would have to mod or would i be better with a vl turbo kit
I bought a RB25 intercooler kit and fitted it upto my HR31 with a RB25. A few extra silicon hoses and it fits, i turned my cooler upside down so the tanks were at the top and it works fine. I didn't cut any holes or do anything to the body of the car, my pipes went between the headlights. Might be different for a VL though.
we just about Build your CAR JOEL,
do you need NEW post every time.
haha you almost have haha i jsut keep running into problems as i go along but much appreciated of everyones help i have got so much more done in the last 2 months than i did in 2 years of it being off the road
and ads i will try that its mainly the comp housing thats the diff between vl turbo and rb25 and i think the rb25 will work the best just may need extendin in some areas to accomodate for the larger engine bay.
My intercooler piping is off a vl so I'd say it will work
vl turbo kit or rb25 kit?
and ads thanks again considering i have a little bit more room in my engine bay it should be a little bit easier haha
The piping kit should work on different coolers as long as the inlet/outlet on the intercooler is in the same spot on both. My GK Tech cooler has 3" inlet and outlet at the bottom on each side FYI
yeah but the gktech cooler is smaller so the piping is suited to that however i found a piping kit with the same set up on the for a larger cooler
Looking at a stock engine bay on a VL turbo, I would personally tackle the job by means of an off the shelf VL cooler kit along with the addition of some cleverly positioned silicon joiners.
It appears just about everything is in the right spot, just needing to extend or reposition a couple of sections to suit the difference in motor/intake design and the same for the turbo (comp housing as stated and position).
Was a decent question IMO, simple resolve too. Best of luck.
hey guyys got a vl turbo intercooler piping kit yesterday most of it fits up well oulet from cooler to throttle body connects up fine with one cut to make it fit the standard crossover pipe however to compressor housing is a diffrent story. i have 2 ways of doing cutting a hole just above the chassis rail sideways or cutting a hole where the airbox used to be and buy a 90 degree joiner and a straight piece of piping. only prob is cutting hole sideways above chassis rail if i was to do that the power sterring lines get in the way so i may go with the hole where airbox was. ill keep posting how im going.
going to be a few days however due to christmas and damn missus wants to go out
hey guys ran into another problem the vac line from actuator needs somehre to go i have read you can t piece it off BOV however i removed my carbon canister and put a screw in the line on the manifold next to the throttle body (not the one on throttle body) would this be a good place to put it or would it onl be a vac line not boost also?
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
