R33 Rb26 Block, Rods, Head, Oil Pump, H-Beams And Itb's R34 Cranks X2
Picked my tailshaft up yesterday arv!! Test fit it and because they've gone to a ford centre bearing and CV I had to modify the mounting bracket a little bit. 5mm of each side and she went up into position and fits well. It has a 1350 uni and flange on the gearbox end so it should be plenty strong! Got stuck in this morning and started on the wiring mess. Cut out all the wires not required that go to the body connector and cut the engine harness out. Need to go through and work out which ones I need to keep and rewire into the new ecu. Should save a small amount of weight as well. I'd love to get in and rip the dash and everything out to completely remove wiring but cbf. Next up was the power harness for alternator, starter etc. It has a few connectors from factory that run out of it. Cut it all apart and removed what was no longer required and put some new corro and taped it all back up and bolted it all back into place. After that I worked out where I can mount the new flex sensor. Found a couple of factory bolt holes and drilled a new hole on the bracket to suit. Need to go get a few fittings and adapters tomorrow so I can keep going.
Nah, im after the more newer looking, one with the OLED display
We revised the neutral wire instructions. The old way was wrong. R34 gearbox change.pdf
Thanks for everyone's reply, I'll make some calls after the weekend. Really appreciate the help on this forum!
The MAF isn't even used to get the engine to crank over. It's only looking at RPM and coolant temperature if I recall the Nistune documentation correctly.
