abflug is definitely nicer. Much better fitment.
PMR33, how low is it sitting to the ground? Would be close to legal/illegal. Would be the only problem.
PSI, price on that one?
It is pretty low to the ground. My car itself is below legal height without the diffuser lol.
  • 3 months later...
No noises what so ever. I made a few additional brackets for it so it doesn't move what so ever. One of the guys here in Townsville got one a few months back for his GTR. He mounted it dodgy as hell (he's pretty dodgy with anything to do with cars though), the whole thing moved side to side and when I saw it for the first time with some mates I said "that thing is going to fly off". Sure enough a few weeks later, it did hahahaha.
But yeah it's fine. Doesn't move what so ever it's on there that tight. Been at plenty of high speeds with it aswell and no problems there. My car is pretty low and it doesn't hit anything at all. I've order the additional carbon vortex generators for the side of it aswell so will install them and post some pics up soon.
If you buy one from PSI Parts, hit them up for the DIY install I wrote up for them. Plenty of photos of everything I did.
Any still in stock PSI?
PM-R33 - how is it going over bumps etc? Does it fit tightly or rattle etc? Do you have any pictures of it close up? Thanks mate.
Hi,
Sorry we have currently sold out.
I will respond to your email in reagrds to shipping times.
Thanks,
Shane
If you can...
Grab an R34 GT-R Rear C/F diffuser or C/F copy for much less eg from JDM Performance here on SAU
Pics?
Get PI Magazine Issue #130 pp38-43 Article called "Mixmaster" Re R33 GT-R (midnight purple)
Brackets can be fabricated by Peter at Bodyform Aero now at Smithfield.
In that PI article Dave, it doesn't say if or how much trouble there was in fitting the R34 GT-R V-Spec rear diffuser to the R33 GT-R.
The article just says, "The exterior is completed with a cutom-fitted later generation R34 V-Spec carbon rear diffuser, a very expensive addition that costs $6000 new from Nissan!"
The one I bought from Eugene at JDM Performance was a whole lot less than half that!
Peter at Bodyform willingly did make up the support brackets + the metal diff bracket for jacking purposes > fitted it exactly to my previous R34 GT-R which was not a V-Spec.
I think the Top Secret one won't match the look of my car. Does anyone sell other designs?
PSI: Thanks for your PM Shane, but I've decided to not go for the TS one - do you have any others?
Any pics of other types?
  • Like 1
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
