As much as i dont want to do this, with the renovations on my house costing more and more, and my other cars needing some attention, ive decided to sell my GZ20 soarer.
Body
OEM Sideskirts and rear pods, 6000K HID kit, LED Parkers and High Beams
Respray in Subaru WRX black with red pearl, Engine bay sprayed in Subaru Forrester metallic green
Paintwork is fairly average, but cleans up ok. Ideally want to have the rest of the car sprayed, Which was next on the agenda for me, But body is straight.
Interior
Bride GIAS II Low-max seats in red on recaro rails, Velo 3 inch 5-point harness
MOMO MOD08 steering wheel in Black suede, Detachable hub kit, Cusco gearknob
APEXi Boost/oil temp/oil pressure gauges, Microtech DASH unit
Pioneer H/U, 4 inch speakers
Engine / driveline
2JZGTE, Fidanza cam gears, GReddy Pulley Kit
HKS filter, 4 inch Stainless inlet pipe
Trust T78-33d 17cm turbo on HELPS exhaust manifold, HKS GTII Copy 60mm gate (Genuine Diaphragm, Turbosmart 13psi spring, deburred inside) with screamer
Custom FMIC kit with stainless piping.
Bosch 044 fuel pump, 2lt surge tank, SARD adj. FPR
Helps Metalwork 3 inch dump/front/decat pipe, 3 inch stainless exhaust with 5Zigen muffler
Microtech LTX-12, 304kw @ 15psi
R154 5 speed, C's short shifter, braided clutch line
OS Giken TS2BD Twin plate clutch and flywheel, push/pull converter
Welded diff, 4.55 CW+P
60mm JAR Alloy radiator, 2 x 12 inch Davies Craig thermofans
13 row oil cooler kit with Titan Motorsport block adapter
Cusco catch can
Wheel and Tyres
SSR Kampter wheels in silver, 18x 9 and 18 x 10 +38 all round
235/40 Maxxis MAV-1 R18 tyres and 245/40 china junk
Suspension setup
Cusco ZERO2 Coilovers (20KG front/16kg rear)
Modified hub ends and LCA's
Whiteline rear swaybar
Bendix Pads
Will make 450kw with injectors, a 2nd 044 pump and a set of cams.:thumbsup:
Can Provide more pics on request.
Price is $13K. Car is currently SA rego'd.
Reply here, PM or Ring Ben on 0430 395 819. Car located in Modbury, SA
Edited by R31 drift pig
https://www.sau.com.au/forums/topic/352224-2jz-z20-soarer-heavily-modified-sa/
Cheers Mate, It'll be even better with 450 at the wheels. :thumbsup:
It already bakes em in 4th gear in a straight line just putting the foot down. 1st, 2nd and 3rd gear are just as useless haha. It's awesome.
I dont want to sell it at all, but I have higher priorities ATM.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
