For Sale Thread
Cubes
Selling some stuff off my 33 as Im upgrading.
R33 M-Spec Aero, Front bar with indicators, Sideskirts and Rear pods, Painted in factory KH3 super black. Front bar is uncut, but vents have been shaved inside to fit intercooler. Also have factory mesh inserts for bar. - $500 ono
Cusco Drag Links - Removing as I'm going to non-HICAS subframe so require toe rods. These will be a complete arm including rods ends. - $250 ono (Will take pic of actual rods when I jack the car up)
JDI Front knuckles. Best in the business. Only Selling to use matching F+R knuckles. Knuckles also have 10mm longer Nismo Studs. Also comes with IKeya FormulA adjust tie rod ends, and KTS bump steer adjustable tie rod ends, to allow for greater movement and extra length the knuckles require. Wont seperate this kit, all 3 parts are needed together. $500.
Pro flow Polished billet fuel rail with injector adapters - Bought black fuel rail instead so not needed - $50
KTS Cradle Collars, Bought these, then bought 33, already had them. Been Sitting on shelf for years - $50
Parts located in modbury. Im away for a week for work, so back next weekend, First come, First Served.
Ben - 0419 809 007
Edited by R31 drift pig
  • 1 month later...
found something i want more so i am parting out or selling as a whole to fund it.
Complete car in bits. no SA rego would need ID check, not defected. PPSR available .
Prices as follows or 0416 580 223 for more information
will do deal for multiple parts, complete rolling shell or even complete car.
13669091_10155186703734896_2633344405020
13819603_10155203457914896_404478025_n_z
13817056_10155203457919896_1111018039_n_
Motor
RB20DET GTS4 top rebuild motor. Head cleaned and faced new valve stem seals full OEM Nissan gasket set etc. 1000
Steel wheeled RB20 turbo 50
starter 50
AC setup 100
P/S pump 80
alternator 50
coilpacks 100
loom 150
ECU 100
igniter 50
stock IC + pipes 50
allow GTR engine brackets AWD 60
AWD nissan engine mounts 40
green label AFM 100
Shell (minor rear end damage as pictured, boot still opens and closes. some rust in places)
semi bare shell 500
headlights 200
indicators 80
uncut front reo 120
guards 100
bonnet 100
Doors 50 each 200
4 door mirrors 80
boot 50
rear bar 50
taillights 150
front bar 80
2.5" turbo back cannon exhaust $100
interior
front seats 50
rear seats 50
dash 200
floor mats 50
stereo: speakers/headunit 100
sunroof/lining 150
a pillar 20
center console 50
parcel shelf 20
cluster 150
climate control 50
Driveline/suspension
R32 GTR box 1000
HD clutch+ flywheel 100
type M brakes 250
GTR cradle with diff 500
gtr GB crossmember 50
front prop driveshaft 80
driveshaft 150
5 stud 100
front LCA pair 30
6 bolt GTR drive shafts pair 200
KYB GTR suspension 200
engine crossmember 50
front drive shafts 150
Any interest in a Cusco BCS for an R33 GTS-T / R34 GTT?
I've had this sitting around for a while, I'd rather see it being used. $50, and I think that's a steal.
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
Also have thiS
R33 grill 1 broken clip no issues  stayin on still stays firm $40
R32 gtr abs motor $200
R32 5 stud hubs $100
S13/180 material glove box $50
R32 power steering pump and bracket res and lines $150
180sx tailight steel garnish 50
S13 180 booster 25 drift pinaples 30
Other  bits ask for price posibly free
 180sx drivers door passenger 180 glass
Rb rubber intake pipes
Stock rb dump pipes
S13 180 materia glove box
R32 glovebox
S14 stock toe arms
Stock r32 rear hicas toe arms
4 bolt diff hats
Stock turbo manifolds
Set of TE37's
17x8.5 +30
5x114.3
No tyres fitted could organise something
located 5062
$2000ono or swap for quality 17x9 +22 (ish) sized wheels
14191533_10205578087852019_1238092657_o_
0416 580 223
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
