Hey all,
Does anyone here install cluches or know of places to install my clutch? My clutch should be ready by wednesday/thursday and it will have the flywheel with it too which is machined. I think it comes with the throw out bearing or what ever its called, I'm not too sure yet. Only thing I don't have is the seals as I don't know which ones(if any) I need to replace.
If I could get my car high enough I would do it my self but I don't think that is likely.
If anyone here in Sydney does clutch installations or knows of any places who don't charge my wallet, that would be great. Lube mobile quoted me $620 to do an on site clutch change. I assume this would be the highest cost so everything else should be less!
Cheers guys.
Oh and car is an R33 GTST.
https://www.sau.com.au/forums/topic/358205-need-my-clutch-installed-sydney/
I got quoted over $700 for a change on my r34 once.
Have a search in the nsw section for goos skyline mechanics, there are plenty in sydney. Just don't take it to someone who hasn't been recommended or they might fk it up, happened to me.
r34 clutches are pull type not push, different removal procedure. The mechanic I took it to didn't know that or that it was an important difference. He's been in the industry for 30 years and assured me that he'd done the job many times.
Point is, if you pay a little more to get it done right you'll be so much happier than going for cheap, them stuffing it up then then stuffing you around.
33 clutches are easy. It takes me roughly 3-4 hrs depending oh how much of a bitch the bolts are, this is on the ground. It would be half with a hoist.. most places charge 4-500 for a clutch and u won't need to replace seals if its not leaking
alright... i'm gonna give it a shot, if anyone reads a headline of "man crushed by gearbox in own driveway" you will know how it went.
So for those who know, whats the process?? disconnect the drive shaft, drop the great box and go to work?
Also, are their any consumables i should look at replacing while i'm at it (figure i'll do my gear box oil again whilst its easy to get to the filler hole).
And last of all, i should probably machine the fly wheel too no? if so is pulling the fly wheel fairly straight forward? and anyone know of a place in sutherland shire who do good work?
*wanders off to find service manual*
Tail shaft comes off, starter motor comes off, loosen all the electronic senders, undo bellhousing bolts, slide her back a little and drop her down.
You're gonna need new seals. There is a lower one, and some rear one. Theres a few more and a complete kit cost into the hundred or two region. I don't know much about the seals so I cant say. Might as well change the fluid.
If the clutch is different to your old one you probably need it at least shimmed to get the old material off so your new clutch can lay its new material on. Air wrench is good here, or a telegraph pole as a breaker bar. I think these are tighted to about 150 torque and loctite. You're gonna need loctite when putting them back on too. I still havent got my clutch or heard from the guy who is making it. I hope it comes soon because I really need to get my shit onto the car.
righteo... found the seal kit for 103 at kudos... so thats a start... i'll try and do a little more digging myself now aswell, cant seem to find a clutch section in engine manual so i might go searching elswhere.
that said, always happy to listen to any ones advice so feel free to keep it coming.
    • This is the clearest explanation out of those: Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension. Basically you turn the engine with the tensioner bolt loose, then use the allen key to hold it while you torque it up. And yes after that a good guide is being able to twist it 90o in one of the long free lengths of the belt
    • good choice....I have a set of those and use them all the time including on this job. Plus, no-one wants a damaged nipple
    • Thanks all, went with nismo strengthened belt and all genuine nissan idler and tensioner Question on RB25DET Neo Timing Tensioner: I have a question about the RB25DET Neo timing tensioner. In one of the videos (minute 20 of https://www.youtube.com/watch?v=17y37BB9xnA and minute 27 of https://www.youtube.com/watch?v=Pb99s2E9xUg), the process suggests tightening the tensioner pulley installation bolt to the specified torque initially, and then loosening it slightly to allow the spring to set the correct tension. Is this the correct approach? The R33 workshop manual on page 74 states: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. The way this is written is confusing. Does this mean: Undo the nut, then reduce the tension by turning clockwise? Snug the nut so it stays in position without applying tension to the belt while removing the timing belt? The manual wording makes it sound like the nut will tighten automatically when you turn the tensioner clockwise , which is unclear to me.   Timing Belt Tension Adjustment Process: After loosening the tensioner nut, you turn the engine two full rotations by hand, which should set the correct tension. Once the tension is set, you tighten the bolt to 43 N·m (4.4 kg·m). Before tightening, you need to insert the Allen key into the hexagonal hole to hold the pulley in place while tightening the bolt. In one of the videos, it’s mentioned that you should twist the belt side to side, or turn it slightly to check if the tension is correct. The belt should turn halfway, indicating the right tension. However, I know that twisting or turning the belt is not a good idea. What are your thoughts on this? Finally, how can I ensure the belt isn’t overtightened? I’ve seen many cases where people have overtightened the timing belt.   Manual Excerpts: Page 74: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. Remove the timing belt from each pulley. Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension.
    • Takes a few minutes to malke one. Wood, or steel, or a wrap strap with some strategically placed solids to provide teh drive onto the ribs.
    • I would strongly suggest using the correct tool. They are not expensive and make the job much easier and don't damage the lock ring. Google "fuel tank lock ring removal tool" to see what I'm talking about.
