  • Welcome to SAU Community
    Welcome to SAU Community, like most online communities you must register to view or post in our community, but don't worry this is a simple free process that requires minimal information for you to signup. Be apart of SAU Community by signing in or creating an account.
    • Start new topics and reply to others
    • Subscribe to topics and forums to get email updates
    • Get your own profile page, build reputation and make new friends
    • Send personal messages to other members.
    • See fewer ads!
    Consider joining our newsletter for the latest content updates
    Click here to register
For Sale Melbourne: Yellow 2000 Nissan Stagea Rs-Four Type S
Privately purchased, imported and complied through J-Spec Imports in mid 2008, this unique, sporty and functional wagon is in absolutely fantastic condition and will suit a fastidious buyer.
Some of the many features to list are;
Factory fitted 'Dayz' body kit and strut bar
Factory 17" alloy wheels
HKS Hi-Power Silent turbo-back exhaust
Cooling Pro 'Stealth' Intercooler
Apexi turbo-timer
Nistune ECU
Pioneer MP3/CD Player
Cargo barrier and rear sun shade
With only one sensible Aussie owner (who hand-picked this car from a Japanese dealership, not an auction) since import, and with just 117,000 genuine kilometres on the clock, this truly awesome all-wheel-drive, turbo-charged sports wagon will be one of the best examples in the country. Serviced by Darren and George at Springy Motors in Springvale, this car has been meticulously looked after both cosmetically (duco still sparkles - always waxed) and mechanically, and is due for its next minor service at 130,000kms. Major service with belts, transmission oil etc was completed at 100,000kms. At last dyno, was achieving an easy 186kW at all fours. Never driven hard - family man driver.
Although the car has NSW rego to the end of the month, I have recently moved to Melbourne and will be registering with full 12 months rego in Victoria as of next week. The only noteworthy issue for consideration as mentioned previously on this forum, is that a slight 'buzz' can be heard when changing from first to second gear when the engine is cold. I have taken the car to Skyline transmission specialists who assure me the 'box will be good for another 30-50,000kms before needing the input shaft bearing replaced. In light of this, I am happy to adjust price from the $15,500 as advertised on Carsales to $14,500 solid, including the 12 months Vic rego to get a fast sale.
Regretful sale. Please contact Tom on 0401 624844 or at [email protected] for additional info or photos. Genuine enquiries only please.
The Carsales link can be found below;
http://www.carsales.com.au/used-cars/private/NISSAN/STAGEA/details.aspx?R=10414341&keywords=bf-22-sv&__Ntk=CarAll&State=Victoria&__Nne=20&__Dx=mode%20matchany&__D=bf-22-sv&silo=1003&seot=1&__sid=12FC7783E8E4&state_id=82&__N=82%201216%20834%20285%20257&__Ns=pCar_PrivateSpecialFlag_Int32%7c1%7c%7cpCar_ImageCount_Int32%7c1%7c%7cpCar_LastModifiedDate_DateTime%7c1&__Ntx=mode%20matchallpartial&distance=25&Cr=0&__Ntt=bf-22-sv&trecs=1
  • 3 weeks later...
  • 9 months later...
 Share
    • That's somewhat of a mixed message or confabulation of two different things. Point 1. Yes, it is generally a bad idea to tap anything into the FPR connection because when it goes wrong the lean condition is very destructive. No, it doesn't go wrong often, but when it does, it is usually because the ignorance of the failure mode is combined with sufficient general ignorance that the failure becomes more likely through ineptitude. Thus, it is generally easier to simply say "don't do it" than try to have a nuanced discussion. Point 2. The Neo's boost sensor "failure mode" should you tap into its connection and have that connection fail is not severe at all. But this is where the confabulation occurs, because you made it sound like tapping into the FPR on a Neo was not as bad. There wasn't any need to bring the Neo's boost sensor up as it was lacking in relevance, even with its previous mention in this thread. /pedant mode.
    • A few things to consider: Is there a good quality aftermarket replacement arm which already has new bushings but also adjustable camber? Rather than the eccentric bolt? Many years ago I replaced all my bushings front and rear with superpro polyurethane bushings. Sure they've been fine. But the castor isn't adjustable and is slightly out, the camber adjustment bolts aren't the greatest and most secure way of adjusting them. If I were to do them again I'd probably just replace the arms with aftermarket ones. I used a 5 ton press to get everything out. The biggest pain is having a wide selection of metal pipe pieces that are strong enough to press things out with. The rear hub bushings gave me PTSD.
    • It will work when it works, the problem is what happens when it doesn't work. The failure mode of the FPR hose popping off is bad news if you get into boost. If you tee it off the factory boost gauge instead in most RBs it's just a gauge instead of being used in the ECU. Even in the turbo NEOs the failure mode is not as bad as it would otherwise be, the ECU uses MAFs primarily and the MAP sensor is mostly for transient handling and overboost protection.
    • Yes you are right. Even conservatively one for 10 years, it would last 1000 years. The Alibaba suplier offer a sample for US$100.
