Both good points.
I'm hoping my one bank rich problem has gone away- I might have fixed it, now just got to wait and see what the car does.
Scotty, your welcome to come up and try to fit on a turbo beanie!!!!tongue.gif
I'm developing a case of the CBF with the car at the moment. It will go away though....whistling.gif
Dale, to be honest, there is no way in hell I'd be taking this out again to coat it.
If I had my time again, I would have taken you up on the offer, and had it done. It'd be well worth it.
That being said, I'm only seeing intake temp of 27 degrees on the freeway @ 110. Round some twists when there is a little more boost, its up to about 31 degrees
Whats that like compared to VQ25dets? I know there will be a difference in the boost, and therefore temp- but what are you guys seeing?
Oh, forgot this pic. This is the cabin filter that was supposedly replaced before I bought the car, next to the new one....domokun.gif
Its not about intake temps, its the rear housing glowing at around 8-900 degrees C that worried me.
My kit is very easy to remove, I can have the turbo out in less than an hour with no hoist. lol. You should have bought the Scotty's Customs kit. :)
But this is the Magical Scotty- I've heard about your prowess- a normal mans 4 hour job is a Scotty 1 hour job!
And it doesn't say HKS on it.... not that I'm a brand whore.... muchwhistling.gif
To Do - Turbo blanket/beanie, and I've got left over heat wrap, so I'll do the dump, and get some flat heat mat on the rest of the firewall.
Edited by PN-Mad
Alex, how far off was the intercooler piping between the turbo and cooler and also the dump pipe?
You gonna wrap/coat the pipe from the cooler to the TB?
We need to talk.... some more
Wat?
See no point wrapping/coating intake piping, unless its to make it less noticeable in the engine bay.
Turbo outlet to intercooler is custom. Used some parts of the kits piping, but most had to be fabricated. Fabricator asked to remain nameless.
Wat?
Just a thought. Engine bay is hot (especially without heat shields over the exhaust manifolds), air is cooled by the intercooler but then must travel the length of the engine bay to the TB.
Would it make much of a difference? Maybe, maybe not. Made a big difference to the touch on my NM35's suction pipe (even the top bend at the rear of the airbox)
The manifolds do have heat shield- HKS supplied- yours didn't?
The temp of air at the AFM which is right in the middle of the engine bay is only 26-31 degrees. I think wrapping the turbo would be more of a priority.
I thought they did, but couldn't remember nor picture them this morning (could only picture the OEM heatshields and I know they didn't go back on).
Ok, I'm going to cut and paste comments from 350z club- I was hoping for some feed back on a problem I got, but I have nil response there. So here goes. And I'ma slap the first C34 owner that says coilpacks....ninja.gif
I have currently found my car has a issue. The car is a Stagea, with a VQ35de motor, and auto gearbox. Most componants are shared with a 350z.I have installed the HKS single turbo kit. Car is currently running stock injectors/plugs and pump, and obviously isn't getting driven hard. I have aftermarket versions of all, but am holding off putting them in. I have a tuner version of Uprev for my car. I first noticed that the car and a uneven idle, and smelt rich. Using Uprev cipher I had a look at the values- first thing I noticed was that the injector Pluse width was uneven across the banks. One bank was sitting on about 2.8ms, and the other fluctuated around 3.8-4.0ms- meaning one side is running richer than the other. With the HKS Kit, all 4 sensors are positioned in the turbo dump pipe. All sensors are active, and have similiar readings- ie- sensors are not dead. The car runs well in open loop, but has a stumble only when it switches to closed loop- ie crusing at light throttle, or at idle. I did some logging with uprev, and the AFR at idle seems to be good at around 14.7-15.0, and both sensors apear to read the same value. I also graphed the comparison between banks, and it appears around the 80%/120% range The problem has been getting worse as the ECU is learning its fuel trim. The engine uses a returnless fuel rail, so one side isn't getting more fuel pressure than the other I have the ability to turn on and off sensors using uprev, and that was going to be my next step. Any sugestions from the experts would be welcome. I don't really want to take my car anywhere, and I don't trust mechanics with it, and furthermore, very few mechanics can live up to what they say they can do. There is a very similar case on my350z.com, but with nil answers.
Update - I had the data open this morning, and cleared the learned fuel settings. That instantly improved idle and the balance between the two banks. I don't know exactly how long its taken to re-learn that imbalance, but it was a couple of days. Looking at the data,the most variance between the widebands is 0.01, while the Banks have a inj pluse width of 2.9ms and 4.1 ms.
Update- So, I unplugged one top O2 sensor thus making the car only run in open loop- ran fine. I re-connected it today, and the problem was instantly back - EXCEPT- it switched sides. IE the other bank is now too rich, and its pulling fuel from the original problem bank. Unplugged both lower sensors and reset learned fuel. It was ok, but learned the problem again in about 35kms.
So Any thoughts here?
Edited by PN-Mad
Did you ask the guys at Uprev?
I don't suppose this is a dumb question, but would this be solved at all by putting in the new injectors?
Otherwise take it back to your Bro Dealer and see if he can smash it with a hammer until it's fixed? :domokun:
I'm currently in an email back and forth with Mark @ Abbeymotorsport. He has been very helpful with the issue. Using Uprev I can log engine data and send it to him- he's taking a look and seeing if he can figure it out.
Will consider hammer option....Or beat it with a stick option...
Edited by PN-Mad
Hi Alex
You said that originally the O2 sesnors were in separate pipes for each bank.
Just a thought.... would repositioning one o2 sensor further from the exhaust port on the block effect the reading that it see's or is expecting to see?
Cheers
Andy
Hi Alex
Cheers
Andy
Hi Andy- The sensors themselves are reading a very similar voltage- and it seems that they are within factory tolerances as per the Service manual.
Just leave it in closed loop, you won't want it learning after the tune anyway.
Hey Scott, Do you mean open loop? My problem exists on Closed loop- ie O2 sensors active. As soon as I hit the throttle, and it pops out into open loop, the injector pulse become near identical, and it runs fine. Looking at it now, I have disconnected one O2 sensor and its running in open loop- the AFR is much steadier, and Inj pluse is near equal across banks.
can you put the original map back in and see how it runs on that?
it may be an uprev thing
Hi Iain, the problem existed before I flashed the ECU- Before I had touched the settings. The flash that I used contains all the stock settings, and has not effected the problem at all- it still exists.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
