If the f#*kers installed a E85 pump somewhere in my part of Australia, I might lean that way. :whistling:
I found a G35 running stock block - 10psi, 22 degrees timing at redline up from 18, and making 414rwhp. Dunno what fuel, but thats a lot of timing in it.
Effectively you can see the octane of the fuel in the map to some extent, as higher octane fuel requires more time to ignite and produce the explosion. At the end of the day, he who runs the least boost and timing for the required power wins imo. (but where is the fun in that? :))
As a comparison Scotty, what ign advance does yours take in the top end on E85, if you don't mind sharing?
These yanks seem to like to put 18-20 degrees in, and they seem to tune on pump Gas, which just doesn't make sense to me knock wise.
Mine seems to run around 24 deg max in the top end under full load from what I can see... (there could be any number of maps overlaid over it,) That is an ethanol tune on a low compression engine obviously, I don't have to worry about knock.
It is an rpm x map pressure so as the boost rises timing gets lower to around 2.9 bar then it drops back to zero.
Lovin' the info Alex and glad to hear that the tune is safer and feels better :)
Re the Yanks, could their numbers it have anything to do with a combo of happy dynos and the seemingly widespread expectation of a full rebuild after 20-30,000 (thus pushing the engine to the limit with the timing)?
Edited by iamhe77
I would have thought happy dyno time for sure, but a Stock block car with 10psi has run a 11.7 @ 119mph, which would indicate the power is there. I just don't know how they can put the extra timing in, unless either a) we are seeing phantom knock or b) they are dosing up with toluene or race gas on the dyno or I guess c) there is a massive difference in pump fuel octane downunder.
That timing issue seems to be the only difference in between my power and theirs. AFR is the same. I don't believe I have an exhaust restriction at this stage.
The ECU is smart with timing - apparently you can make changes to the figures, and the ECU will take a few runs to compensate for the changes and find out the best path. Too smart for its own good.
Very smart but when you take the knock sensor out of the equation you are asking for trouble. Essentially you want to make smooth power so the knock sensor doesn't back the timing out.
Did you look at the HKS manifold adapter? That's what I call a restriction, but the results you have seen, are they running the same kit?
Nope, he's running GT25 twins. I'm just using it as a stock block comparison.
Manual Z using F-Con & HKS kit is 245kw at wastegate pressure. I have no idea if that's in la-di-da land or not. I should get him to put it down the 1/4 . Maybe I'll just be happy!
True that the HKS adaptor isn't going to flow like twins will.
atm its single tyre frying time. rwd and open diff is silly.
3 inch, and should be all the way.
I think Scott made good power with a Fujitsubo, which is essentially the same exhaust. We can always drop it and see.
There is a big HKS Cat in there too, which I dunno how good they are, but wouldn't have thought its shit.
hey alex, congrats on the successful re-tune. i think the HKS supercharger kit and turbo kit make pretty much the same amount of power at stock boost for the vq35. the 2006 rev-up z with supercharger and a 2004 superchargerd Z in sydney both made 240s and Bao's 2004 turboed Z made around the same. i lost 20-30kw on them due to the auto vs manual drainage. maybe the 4wd setup on the stagea casued you further loss even though you swaped to rwd?
in the end the numbers looks pretty much on the money for us slush box cars i guess. however i will never find out if my plenum spacer is actually sucking power from my car lol.
Craig, your a massive Trolololol. Come back when your car doesn't sound like a milo tin full-o-bolts. Thanks for waking me up last night to mate- Obvious drunk is obvious. :P
I think I found a restriction, but I'll wait for proof before putting it out there.
You just have stronger Rods ok... Its not all about the Rod.
We can do craigs next week if he is keen, i wouldlike to do it one weeknight, give him a nudge in this direction :D
i have been looking at the emanage software and it lookspretty basic, i think the stock ecu is going to be the issue.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
