I had intended to take photo's as I did the work, and write it up into a guide - but alas I was too focused to remember to grab the camera :whistling: (yeh focused, that's what I was)
So I had a broken wheel stud on the front drivers side wheel
- took the wheel off, removed the 2 18mm bolts that hold the calliper on
- removed the rotor and begun working on removing the broken stud
- I'd been told the basics behind removing the stud by a tyre monkey at Bob Jane T-Mart, as per his instructions got out the hammer and started banging away
- that sucker was in there tight, and not having a decent sized hammer was no doubt making things harder
- tried to get the WD40 working for me, but it didn't seem to be helping much...
Then the craziest thing happened .... I had an idea!!
What I wanted was to make the stud smaller than it was, and of course the best way to do that is to cool it down.
As the freezer wasn't an option, I started racking my brain for ways to cool the stud, but not the hub (i guess that's what it's called) - as I don't live in a science lab, there was no dry ice at hand.
But I did have the next best thing - a can of butane lighter fluid.
The liquid/gas will turn almost anything white with condensation on contact, it will also make most surfaces so cold, it will hiss and crackle when you touch it with your hand.
So I sprayed the damaged wheel stud with the butane, waited for a minute or so, then sprayed it again - just to make sure that it was cold all the way through.
After making sure there was no butane smell in the area where I was working, I gave the stud a half assed love tap and to my amazement the damn thing moved, another quick tap a little harder than the first and BAM stud is out - That was easy.
So the moral of this story is - if the big hard stud won't come out of the tight hard hole, give it a cold shower of butane :P
I hope this info is helpful to someone out there at some point.... else my puns were for nothing.
-Raven
https://www.sau.com.au/forums/topic/379797-replacing-broken-front-wheel-studs/
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
