Ok, small update. I spoke to my friend who is an engine builder about the lifters. He can't be sure until he has a look over the head, but he suggested either poor maintenance (lack of oil changes), abuse to the engine (starting engine and not allowing it to warm up) or possibly overheating of the engine could have caused the exhaust lifters too look as they are.
Today i decided to pull the bottom end down. I removed all the pistons and the crank. And needless to say, all the bearings are worn and will have to be replaced at the minimum. It doesn't look like they have starved of oil.
My conclusion is its had a very poor service life. Possibly had its first service far too late and may have only had one other service. I know it has been service once here in Australia, as it had a bursons oil filter on it. I would say its also been started, thrown in gear and driven. As thats what most people do;, start > throw in gear > throttle > BAM, heaps of engine wear. Given that most engine wear is caused on start up/warm up. But unfortunately the average person doesn't care/know. i think this is where this engine has received all its damage from.
I'm very very pissed off and frustrated to say the least. This was meant to be an engine to get my car running again until i've finished building my RB26. This is another really annoying set back.
I'm not sure where to go from here. Do i replace all the bearings and rings and set it back to Nissan tolerances. Or for a little bit more money i could put some CP forgies in it, then you might as well put arp bolts in the rods, but for a bit more you could just buy forged rods anyway. Now the crank is out i should get a crank collar fitted and have the crank grub screwed. It just snow balls out of control. Where the hell do i draw the line, a line that i'll be happy with knowing the engine is going to run happily for a decent amount of time to come.
Unfortunately today has got me really questioning myself why the hell i'm into cars, wasting so much money and time and every time i eventually get the damn thing going again, it just breaks something else. Really frustrated and over it! sad.gif end rant.
if its just a temporary motor throw some new rings and bearings at it and drop it back in. provided you can do it yourself it shouldnt set you back any more than $500 for everything. if you cant do the bottom end find someone local on here who can and offer lots of beer.
i think incorrect or too thick an oil can also cause the wear you have seen. esp on cold starts where the oil is too thick to flow between the bucket and head properly.
Simon, Matt Millard also suggested this as another point of wear.
Nissan specify 7.5W30 factory which is pretty thin.
I can change rings/hone bores, change bearings myself.
But trying to work out bearing clearances to nissan specs looks tricky.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
