Hey,
I've bought a R31 GXE and would like to know which aftermarket Air Pod filter, Exhaust, Extractors and Muffler I should get for it.
I'd like to know what brands to watch out for (as in dodgy) and what brands to try and get for best performance.
I live in Victoria so I'd like to know which shops/factories to get these from too.
Cheers guys!
Yeah i've read through that before. I know what i want tog et, i was looking more for what brands i should get.
Especially in suspension because i don't want to end up with un-RWC low and what-not.
I was thinking of going 2.25" with Dual Tip.
But not sure how to go about it.
Going to scrap getting a pod filter and just get a High Flow panel.
Will replace the tires (not sure which brand tires to get)
Would like to know what extractor's to get, i've been recommended to get Magnaflow Tip/Muffler.
Also which springs should i get (as in how low) to be low but RWC still (for front and rear).
Should i replace anything else in Suspension/Brake setup?
This is on a budget by the way.
Sorry mate, i'm a bit of a noob.
But how much will all that cost me?
I would more than likely have to get a mechanic to do it for me (my dad used to be one but he might not know everything).
How low would the Coil Over setup bring the car down?
Or would i need to buy new springs too with that
Oh and which R33 rotors and pads, on garage 7 the Adapter Kit says it needs drilling with any non GTS brakes, so do i just go with GTS ones?
Where would i find some, besides ebay etc.. I want this done sorta proffesionally yet cheap.
Angry's struts look promising, yet somewhat confusing on what i'd need to do to install them.
Also what parts would i need for Exhasust system?
I was thinking Hurricane Extractors (or some pre-owned Lukey ones), with 2.25" piping and High Flow Cat (or just normal) and Magnaflow Muffler and a dual tip
I'd just like those opinions, i've searched everywhere and haven't found much that's helping, especially since i don't know all the lingo for car parts etc..
It doesn't matter anyway. I know what i want now, you can lock the thread if you feel.
just turbo it n put a dowse pipe on 3 inch exhaust injectors nistune fuel pump cooler and screamer dont worry bout this non turbo boring shit its all money wasted cos u get a shit noise and no power my mate has a 31 with the same boring shit u wanna do and its slow another one of my mates turbo'd his 31 with the above mods n it beats my evo 8 so just turbo it or buy something good
Ok only because im a nice guy ill go through it with you.
Coilovers can be made to what ever height you like as they are adjustable. They also have the options on damper and camber adjustment apart from the rears witch are height and damper. If you went Angry's coilovers you will have to take the coilovers and your old struts into a workshop and have the "base, feet" what ever you want to call them welded onto the coilover.
If you wanted bigger brakes you could go down a few paths the path i chose was R33 turbo as they are ALOT bigger than the shit 31 brakes and are reasonably price second hand, then you would need bigger rotors to suit witch would be R33 GTST rotors. (I can help with standard or slotted rotors as i work for Nissan) Because these rotors will be 5 stud you will have to get them re drilled to 4 stud to suit unless you done a stud conversion.
Now to get these rotors and brakes to work with Angry's coilovers you will need the G7 hub adaptors witch i am running too, they are by far the easiest and cheaper way of getting bigger brakes in a 31.
http://www.garage7.com.au/home/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=277&category_id=383&option=com_virtuemart&Itemid=53
Of course you don't have to go R33 GTST brakes but that's upto you pretty much anything with a floating hub.
You will need to read this before installing the brakes:
http://wiki.r31skylineclub.com/index.php?title=Brake_Upgrades_Miscellaneous
Now because your brakes will be bigger the next question will you current rims fit? Im smaller than eg R33 GTST rims 15inch? Then your 31 depending what width and offset will need 15inch or bigger.
Get some new wheel bearings and repack the bearings whilst your at it so it's all fresh.
If you wanted to go down the S13 front end conversation:
http://wiki.r31skylineclub.com/index.php?title=S13_Suspension_Conversion
Alot more money involved as you require more parts to get pretty much the same result. If you went the s13 way you wouldn't need the G7 adaptors as the s13 hubs will fit the R33/R32/S14 etc rotors and caliper's will bolt up.
Not overly hard if you are mechanically minded. I done a full coilover and r33 brake upgrade on my coupe and it has been fine. Just follow the links and you shouldn't have any issues.
Coilovers aren't legal unless you get them signed off by an engineer. Varies from state to state.
I think i covered everything.. :thumbsup:
Yeah i've been over at the R31club forums and they pretty much said to get pedders reds or those U-welds.
So i got them covered, i aslo went over that R33 brake conversion and would get that covered, the rims i'm planning on getting would be 115x7 with -4 offset i believe.
I'd just get the GTS R33 brakes as getting the slotted and drilled just seems like a hassle, as i'm already paying for adapter kits etc..
and i'm not sure a 5-stud conversion is RWC for a R31, but i'll sus it out.
thanks mate!
P.S - It appears the GTS25 Calipers fit inn 15" wheels.
thanks mate!
good thinking re brakes and stuff, just keep in mind that all the mods you want to do with the motor wont make much difference to power altho you might sound you are going faster! the
30E is a bit of a lame duck when compared to late model twin cam/turbo motors
when it comes to power/bang for buck
  • 1 month later...
Well things have changed since those months ago.
I am buying some new 16x7 +20 Watanabe's, and getting Angry's Emotion Coilover's (when i get money and will be installed by a suspension workshop).
Won't bother with a brake upgrade as the car's brake system is adequete for how i use it.
Now to save money like there's no tomorrow!
If you are looking at going faster then you are FAR better off turfing the 31 and getting a 32/33 or 34 as they are better platforms for mods . . . . they have good brakes / IRS / turbo motors and heaps more aftermarket support than the 31 plus 31s look like pintaras
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
