Hi,
Had my GT3076 installed yesterday and the car wont idle after driving. Drove fine before the switch. Could it be tune related? Previously had a PFC tuned for a FMIC 3" exhaust, stock afm and R34 NEO turbo. only things to change are some of the plumbing from turbo to cooler, intake pipe and obviously the turbo. If I start it cold it idles fine. Once i drive it and pull up in traffic it just stalls and takes about a minute of me trying to gently feather the throttle til it idles. Any help please?
https://www.sau.com.au/forums/topic/397005-hard-to-idle-after-turbo-install/
  • Replies 58
I hate to say it, but what the hell has the tune (or lack thereof) got to do with hot idle?
We're talking about no revs and no load and so the turbo has no effect on the idle. Things like changing the BOV configuration and so on might contribute, but he could have strapped a T88 on there and you'd still expect it to hot idle.
And he could nurse the car along with little or no boost to drive it home and again the turbo would have no impact on the way the car drives, and even if he made a little boost here and there, the bloody car has an AFM so it's quite likely that it could handle it just fine without turning the plugs into charcoal crayons.
My vote is also on hoses or similar installation whoopsies.
Its a GFB bov and its been on there for years. it drove fine to get it home in the fact it was smooth and could change gears etc but as soon as the clutch went in it and the revs dropped at a set of lights will stall. The gear changes dont see the revs drop enough so thats why it seemed to drive if that makes sense. Even sometimes on decel it can get a bit shuddery. I dont intend on driving it anymore until it is tuned I just dont want an already expensive tune to turn into an expensive fix and tune so was just looking for an answer in case it was something I could do and then get it tuned.
Edited by FordyR31
Do you guys do a risk analysis before you take a dump? Sorry, should go back a step; Do you guys do a risk analysis before you eat something spicy?
Nah, sorry mate, can't put it on the dyno, not safe to drive it onto the rollers....
Idle issues; check vac lines, afm may be a bit touchy if you have a short metal intake pipe or an atmo BOV so the tune it may need a touch up in that area possibly combined with adjusting the idle screw.
The bov is plumbed back permantly on one side and i have tried with both the atmo attachment and the plug in so it was completely recirculating. Again this is no change to how its been for the past 5 years. yes it now has a steel 3" intake pipe but all the plugs are the same for the bov and breather etc. its just a metal copy of it pretty much to retain the stock airbox until i get another one made and afm position.
Is the IAC valve plugged in?
We need more information on what has been done.
For all we know, you could have bolted a bigger turbo, cams, injectors, blow through super charger, and hooked up a bottle of NOS.
More information please, not just dribble it in as we need it.
I have already mentioned whats been changed.
before issues:
S2 RB25DET
Power FC tuned
R34 NEO turbo
Splitfires
3" exhaust
FMIC
Recirculating GFB bov
Stock intake and airbox
They are all the mods that were done and it was running perfectly.
Changed the turbo
Modded the intercooler pipe to suit
steel intake pipe with all hoses attached as if it were the factory one.
The tune could be the issue for the fact that the turbo could be a bigger restriction on the intake side hence snuffing the engine because the turbo is trying to effectively stall and the engine can't breath enough through the intake hence why it stalls. Would be unlikely but possible.
As said before, it sounds more like vac lines of some sort allowing it to gain air that it doesn't relise it has hence leaning out and stalling. Check ALL piping (before turbo, after turbo and even manifold, even if you haven't been there as you could have bumped it off) as even a leak from a clamp not been done up can suck air through which the engine doesn't know it has. It will idle when cold due to the engine automatically enriching the engine till it gets to temp. Effectively counter acting the air in the system it doesn't even know about. When it gets to temp it leans back out and stalls for been too lean.
You could have gotten oil from the filter if its an oil based filter onto the air flow meter even, or simply it could have gotten dirty while installing the turbo as you only need to get a little bit of crap on it to make dramas. For this one, get some contact cleaner (yes contact cleaner not brake clean or anything else) from super cheap/ autobarn/ etc for a couple of bucks and clean the fine wire in the center of the airflow meter where the air passes over.
Give that ago to start with.
Matt
Youve stuffed the plugs because your driving a car tuned for a 1hp turbo which now has a 500hp turbo.
The ecu measures load by AFM voltage, I imagine that the AFM voltage would be a little higher when your cruising around (using some throttle) than when using the tiny turbo.
Get it to a tuner ASAP as the extra fuel would be washing down the bores and potentially FK'ing the motor.
I don't understand this???
AFM does have an effect but it only measures the amount of air passing over it.
The amount of air passing over it effectively cools the wire causing the wire to have more resistance in which alters the voltage giving you a reading.
The input voltage never changes. It is set to 5 volts from memory and is so that even if there is low power, spikes, etc it will still read effectively.
Engine load on the other hand is measured by a number of factors. These include tps, road speed, boost/vac, inlet temps,O2 sensor readings, etc.
In my opinion, by changing the turbo it has done nothing to the lower part of the map. This is because the AFM is still reading the amount of air coming in as nothing has changed that fact that it is still cooled by the amount of air coming in. Therefore if the turbo was changed and the air increased or decreased it should in theory measure that anyway and adjust to compensate. If it was adding too much fuel it would be picking up that it is doing so via the O2 sensor and still it would adjust to suit.
I do however agree that the engine should be tuned for the new turbo asap as the amount of air the turbo would flow at higher rpm compared to the older turbo could effectively have the afm run out of room to measure therefore leaning the engine out causing detonation or depending on the safety setups in place on the power fc could richen the A/F mixture causing it to wash bores.
If this is incorrect please explain to me as more info can never hurt :)
Another thing to check is to make sure you haven't damaged the O2 sensor as well, as this is used under cruise and no load situations (idle) as a closed loop system and is also disregarded during warm up.
Yes, the AFM has 5v in and the element measures flow by vibrations in the passing air and outputs a voltage. The ECU reads that as airflow and plots a certain point on its mapping with that data along with other data.
To say it would little impact on mixtures is ridiculous. Thats like saying boosting a stock R33 cant possibly make it hit R&R................... Wrong right? Yeap.
The points that are likely to be screwing his mixtures badly are the cruise areas of the map like I said. Between 3000 and 4000 rpm where the turbo IS pumping a fair volume but is not yet 'boosting'. You have to agree that the stock turbo would not suck an identical volume to a 3076R at that level, and its doing a little more than idling along (consider your in 3rd gear at 40kmh and start trying to chuff along to 60kmh). Thats going to be a big difference in flow from the compressor between the two, and subsequently a big difference in the resultant map trace.
I hope Ive explained it clearly enough for you. My theory is that his plugs are fouled. Remember that his comments were, it ran like shit after I drove it a while. Not, my car ran like shit ever since I installed the new turbo.
Wrong wrong wrong.
Nissan AFM is a hot wire type, not a vortex counting type (like Mitsu). AFM is THE thing that determines engine load. What the AFM says the load is, that's the load. Doesn't matter how you get that load - by hanging the AFM off a big motor, or hanging it off a small motor with a little turbo working hard or a big turbo hardly working. The load is the measured air quantity.
THE SIZE OF THE TURBO WILL HAVE NO SERIOUS EFFECT ON THE MEASURED LOAD OF AN ENGINE THAT IS JUST BEING DRIVEN AROUND GENTLY. It's only when you get serious revs and boost happening that the differences in exactly what revs which airflows happen at start to affect a tune.
As I said previously, he could have bolted a T88 to the engine and it should not affect how it idles, and it should not affect low load driveability either. In fact, you could try to drive it quite hard, and as long as the previous tune covered the low load (ie, no boost) high rev portions of the map properly, it would probably be quite fine then as well.
Drive it around all you want, under light loads your not going to wash down the bores and destroy your engine, what a joke! Whilst i wouldnt reccomend it, 90% of the time it'll be fine to thrash on low boost too, aslong as the previous tune isnt miles out.
It sounds like a leak somewhere, check every bit of the intake piping for leaks and if you cant find any you could try pressurising the intake and using some soapy water on the joins. Otherwise if your certain its not leaking, try cleaning the afm.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
