No centre caps :(
So question for those in Japan: where to get them, and how much are they likely to cost!?!
I was searching the auctions trying to find a set, no joy, but I did get the idea: would any centre cap fit (i.e. Rays etc) or must I get WORK specific ones...
Thanx
Dave...I have no idea if the Rays ones would fit. But looking at the pdf for your wheels they don't list any center caps. You could try to contact them and see if they can help? Maybe they have other center caps that might fit your wheels. Or just leave them...
(BTW...damn they charge a lot of money for custom color!)
Centre caps are available for the WORK Emotions
Though in every case they're always silver (not white). I'll have to ask down at my local wheel shop see if they can order a set, though in the meantime I'll keep my eye on the auctions, most likely someone will appear selling a set :D
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
