CP forged 86.5mm 1000HP manly rods and a tomei head gasket.
you should be sweat to ~800hp than :-) - BTW Did they grout the block?
Upgrade oil system for insurance, get some head work for response :-)
Its tuned on an incoming tide :laugh:
LMFAO FOR AN EXTRA 50 AT THE RUDDER KW
yeh oil system has been done, sump and cam baffles, oil restrictor, OEM GTR oil pump with upgraded pump gears to make sure they dont crack.
Im not 100% on the block i know they have had to bore it out to fit the pistons and then everything else that goes with doing that, ill have to speak to the guys at the shop to find out everything they did to it.
as far as the head goes i have NFI atm keep in mind im not a mechanic by anymeans and im just learning how all this stuff works now, i have been told the head had more damage then 1st thought and has had to have some more work done at the machine shop then they thought it would.
BTW found u a box
http://www.skylinesa...s-of-256-parts/
and i got some more info on the Varestone rims also
http://www.varrstoen.com.au/shop/2-2-1-wheels/2-2-1-rims-wheels-18i
they clear brembos with ease no issues, one of my m8s in SA said the local boys run them on there drift missles.
Edited by T4NK
Nice, now u just need to find me a set of Volk GTC in 18x10j +12 for uner 2.5k :yes:
Im so torn on what rims to get one day i want GT-C the next i want TE-37 the next i want some random set of work rims, FML
Edited by T4NK
Who said i was returning the favour :O haha
That would look good, what colour you looking for?
in the Volk GT-C gold center chrome dish, there is a few sets going around but they are all stagerd fitments
in the TE-37 White or bronze
in the random Works white or bronze again.
If only these where +12
http://www.importmonster.com.au/shop/product_info.php?cPath=40_45&products_id=1296
Edited by T4NK
i think the rim you have currently on the car look pretty smick.
Yeh i dont mind them but they are a POS to clean, they have heaps of tight spots in them and i know 1 of the rear rims is buckled, i may look into the cost to have them fixed and get some center caps
BTW they appear to be GTR Nur spec Enkei NT03-M rims, i have never seen another set of them in my life, they have GTR NUR stamped around the center hub and are identical to these
http://www.enkei.com/nt03m.shtml
http://www.ebay.com/itm/LIMITED-EDITION-ENKEI-NT03-M-18x9-5-27-5X114-3-PURE-WHITE-EVO8-9-X-FD3S-SUPRA-/261068728160?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc8e8a760&vxp=mtrIm
considering a set of these in white, for 2k i can get a full set, with caps and lock nuts posted to me using DHL
http://www.perfectru...result_mode=qui
Edited by T4NK
oh em gee!! thats so kewl.
wonder how much aca will pay me for the vid if i say its a 40 zone?!
I will tell them i was doing 40 and you were dangerous driving at 10 and going to cause an accident :P
    • I had a 1981 ALFA with an electronic speedo sender that would work for months at a time, and also noth work for months at a time.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
