Woo Hoo Dump Pipe Finially Arrived
Originally posted by Black33
I can help with a couple:
3. I THINK around 12 but dont quote me. Heaps of threads on this topic - do a search!
that wouldn't be stock. no way. way to lean for stock. did you mean after safc? im planning on running 12:1 with safc...
thanks for the directions...!
5. I think inasnt meant that the dump he had did not exactly fit the front pipe he had. I don't have this problem because I don't have a front pipe and am getting a 3" one made up when they put the dump on (on sat. :)  ). When they make it up they can just make it to suit the dump - but he had no problems with it fitting onto the turbo. Anyway I think it was only a little bit off and the exhaust place would just cut your flange off and rotate and reweld to suit!!
[/b]
ahh no i understand the difference between dump pipe and front pipe. i was on the understanding that the dump pipe and front pipe were the same things (wrx speak) now that i have a full understanding of the new lingo, i will most likely need a front pipe and dump pipe...
cheers, i'll be interested to read about your install and results post saturday!
  • Replies 152
1. I have posed and so has black33 pics of the dump pipes in this thread.
original (oem) dump pipes, not the arrow diff ones...
2. The oulet flange for the r32 and r33 turbos are the same, dont know about the r34 tho. If the r34 has the same turbo as the r33 then yes it will fit.
T3 afaik?
3. my stock a/f were runnin near 10.0, which is rich as a bitch!
yes, rich as - but this isnt too much of a surprise. could you send me your safc settings pls???
5. the outlet of the dump pipe to front pipe is angles differently to the stock dump so i had to get my front pipe cut and rotated to join the new dump, no dramas with that part anyway!
this wasnt the case with black33 then seeing as though you had the same dump pipes???
6. what r u doin sneeking around the vic section??!! hehe kidding!! :)
i know that i dont browse all sections of the forum ... in which case i think everyone is missing out on lots of relevant discussion topics.
i mean this thread for instance, had nothing to do with VICTORIA, besides the people who created it, ArrowDiff are located in Sydney and the topic of discussion is very relevant to everyone..."me no understand"...
firstly i have the rest of the system, 3inch front, high flow cat and 3 inch rear. blacks exhaust is the stocker!
as for me sending u the s-afc setting, that aint they way to do it man, u need to run it on dyno and adjust it according to the a/f ratio readings or else u r gonna reck your engine if it runs lean!
only way to find out if the dump will fit is to take your stocker outand compare it to the r33 1!
Originally posted by franks
i know thats not how you do it :)
i just want to get a basic idea of where your pulling out fuel...
also, on the safc isnt there a function where you can literally cut fuel when you back off the throttle so as you dont get backfires???
well my s-afc setting basically start at 3000rpm with -3% and sorta progresses more and more - till 7000 rpm where its -15%.
as for the dec-air function i havent got it to work properly
WELLLLLL, finally installed it on Sat. along with a front pipe and had my cat opened up to 3' front and back!
Have to say though, haven't felt any difference - maybe 'cos the weekend was so damn hot here in Melboure - will have to drive it on a colder day and see if I can tell if it did anything.
u basically got a bigger exhaust and u felt no difference?
WTF!
I felt better spool from new 3inch exhaust before dump pipe was on
I always had a super dragger exhaust on there but only from cat back. On the weekend I only had the front pipe done and the dump installed.
I swear, if anything it feels worse. I get a flat spot over 4500 rpm when stretching 2nd and before when I took off hard in 1st, it struggled to keep traction but not anymore? don't get it?
the weekend was a bad time to test the car, as it was hot as a mofo!
u should come over and drive my car and see the differences, i can wheelspin my 255's at only 7psi boost even if i take off slow and then floor it all the way through 1st
I don't think I want to go as far as a PFC, too much $$$$$.
Keep me in mind when you sell the safc if I haven't got one by then (when would that be?)
What power increase (from where I'm at now) do you think I could get from the intercooler and from the SAFC??
i am gettin a cooler by the end of the year, then i will get my pfc.
For now if u can get a s-afc second hand for around $400 i would get it then upgrade later like i am
cool, will keep an eye out.
do u know where can i look for one second hand for $400 apart from our forums?
u can get em new from http://www.nengun.siteblast.com/
for about $520 i think, or just keep an eye out on here, and skylines downunder.
ex-static, 30kw from an safc tune? that's abit rich isnt it? was there an inherent problem before the safc tune? did you raise boost? any other mods that came with the safc install and tune? 30kw at the wheels? mygod... was it done on the same day and same dyno!? id hate to think how much power a new turbo gives you!
black33, you'll be very lucky to get a 2nd hand SAFC for $400, i've been waiting for weeks! best i've seen is $480. Noone will go lower than $500. At the end of the day, i think im going for a daughterboard for a couple hundred more and get access to fuel and ignition mapping and tuning.
as for choice between SAFC, i guess it all depends on what you want out of your car down the track? i guess you wont lose much on resale value with an SAFC but you've still gotta install, tune and then remove later on if you do decide to go PowerFC. i think in all cases, your best bet is to do it right the first time, that way you get maximum enjoyment, least headaches all the time...
theres on for sale now by white_r33 480 inc install... but i think nismo GTS-X has his eyes on it so u better hurry :D should be able to get 450 and u pay for the shipping which will be about 11 dollars something.
I don't know what it could be caused by - it definitely feels worse?
I'm thinking, maybe now that I have the full exhaust that they fuel ratios are really screwed and I'm gonna try gapping my plugs to 0.8mm. Am I on the right track, any other explanations?
I suggest u go straight away and get sum ngk 0.8mm plugs. Then get that s-afc and get the thing tuned, and u will feel the difference.
When i got boost controller put in and upped boost to 10psi it was missfiring upto with the normal plugs!
black r33 wind your boost down a bit and see if it help wind it down to 8 psi or so more boost doesn't nessacarliy maen more power then get the s-afc tuned.
franks here in melbourne we have had some very good results with the s-afc tuning 15 20 rwkw iis gain quite often.
exstatic doesn't need to jsut ify the gain cause most of us were there when he got the gains and saw them with our own eyes
meggala
Franks,
Same Day, Same Dyno, a little bit of boost. from .6 - .7bar
It wasnt just my car either Grim on these forums, had a good 20-25rwkw gain on the same dyno, same day, same tuner.
Great results can be had from an safc when tuned right! I guess it depends on your budget, and how far you want to go in the future.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
