Change Gauges In R34 Gt-T Sedan Gauge-Cluster
AlexG
 Share
Hey guys.
Long time follower, first time forum-join-iner.
I just have a quick question to ask someone that's either done it, or knows if it can be done.
I have an R34 GT-T Sedan. I want to replace the stock gauges in the cluster on the top of the dash with some after-market ones.
I want to know if they can just be placed right in the same mounts and just re-wired or if it's more complicated then that?
Any help would be greatly appreciated. I've put gauges in cars before but I thought I'd ask before I go ripping stock shit apart lol.
Basically the reason for doing so is the volt meter doesn't work and the boost one is a little dodgy. Plus for style as well. Looking at some white face ones like GReddy or something.
Thank you very much :yes:
Hey Alex,
YES, it has been done plenty of times before so you are in luck :) Have seen both the 52mm and the 60mm done successfully. I am looking to put some blue stepper motor gauges in mine in the near future so maybe do a DIY thread on it so its fresh (If you search you will find 2 existing threads on this to give you a hand with it)\
Cheers
Mat
Theres a few ways you can do them really. I found that 60mm Defi guages did not fit and i had to dye grind the surround and wedge the gauges in so they pop out 10mm from the holder (couldnt fit the glass back on) and they looked really good !
Cant comment on other 60mm gauges but i would go with 52mm if you want simplicity.
As for wiring the circuit that powers the tripple gauge holder is actually 1 solid single piece PCB. The only thing you can tap off from the connections there from memory was your power and earth wire (not sure if i ran an external earth all together though) which will get all your gauges to light up and your volt to work. From there you need to run a sensor with a sandwich plate from your oil filter for your oil temp and take it incabin where the gauges are and the same thing for boost with a tee'd off vaccum line.
If your mechanically minded and know how to use a Volt meter its a pretty easy job. If you have little experience then i advise you take it to someone or call a friend to help you out cause there will be alot of head scratching involved lol
Edited by nomnomv8
post-11869-0-26047200-1346425194_thumb.jpgJust done mine with 60mm Defi's, have done them on a previous R34 aswel.
First time i mounted them inside the gauge pod and just modified the original gauge mount inside to hold them in. Looked neat and they were hidden when off, bit of trial and error getting them centered.
This time i wanted them on the outside, so i just removed all the inside's, cut some slots on the round part, then heated it with a heat gun and forced the guage in, so its nice and firmly mounted once it cooled down, doing it this way there is a gap as the pod isnt flat, but i wanted this look this time.
As for the wiring i used the orignal gauge wiring to get 12v+, Ign 12V+ and Illumination 12v+ and then i ran a seperate ground.
Edited by msports180
 Share
    • I'm still waiting for the bearings from Jesse Streeter so haven't fitted them yet. King pins don't fit though, if you're thinking about doing it get the king pins now because the new stock seems to be 3x the price. I got one from Kudos and one off ebay from JP 40022-60U05.   If you get them from NZ get him to mark the value down, I got touched for $2k in duty and gst
    • Alright guys, this thread really got to me, so I thought I'd do the best thing I can, and change the mowers oil.   So here is a photo of me draining it. To be totally honest, I see nothing wrong here, and think there's easily another 5 years in this oils life. But, now I've hit my next conundrum, some twit drained the oil, without having bought any new oil... Should I splurge and use olive oil, or will canola oil do?   On a serious note, I'm undecided if I REALLY need to buy 4 stroke mower oil, but some claim normal motor oil doesn't have extra zinc or some shit in it.   Also, mower has started getting blow by, it isn't pumping oil out the breather, but it is pumping out a lot of exhaust gas... Which is then making the mower hunt a lot... I'm think atmospheric vent, with a filter... PS, this is a mower I was given years ago, have had to rebuild the carb, build my own blades for it, fix up valve clearances, and then make it really sing way above any rpm it wants while I punish it in the back easement, so no, I'm not spending anything more than I need to. The thought of buying an air filter is bad enough to me and I'm searching for one I think I had on a catch can...   So while this mower is a cheapo, flogged to death, revived, flogged again, revived, flogged again, and now being turned into a zombie, does any one know if I'll seriously shorten it's life if I use something like Nulon X-Pro 5w-30, or HPR 5 5w-40 instead of spending stupid money to buy SAE30 4 stroke lawn mower oil? (And yes, if I drank alcohol I'd happily pee in the fuel tank instead of putting fuel in it... At this stage I'm siphoning year old 98 fuel from the Subaru each time I need to refill the jerry... )   So... Input?
    • @Kinkstaah So... I took your advice and looked under the bonnet... is this where the rubber strip should be? 🤣🤣🤣🤣🤣🤣🤣🤣🤣
    • 'Course, he also used to say, "If it's got tits or tyres, you're better of renting it by the hour. It will cost you less in the long run."
    • migrate-from-158-cefiro-parts-classifieds
