  • Replies 64
Street to Track
I have read through the "-5, vs -7, -9" thread, but they mostly compare the general specs of -7/-9 vs the -5.
In the end, all i got from it was that the -5's are laggy on stock displacement motor, and the -7's-9's are better for a street car on stock displacement.
Wasn't much info with the -9's vs the -7's though...-7's have a slightly smaller compressor wheel, not sure if the -7's are still capable of 300-350rwkw though, or what kind of power they are capable of vs the -9's.
EDIT: Re read - Seems to be
-7's = 300rwkw
-9's = 330rwkw
EDIT: Believe they are rated at the same horse power, maybe the -7's are a little less, but should be more responsive due to the slightly smaller compressor wheel. http://homepage.ntlworld.com/tbroom/Turbos.htm
Edited by Booki
Now even more confused, because on kudo's webpage, both -9's and -7's are rated at 620hp...
So who is right? :\
Quick answer would be good, ive tried searching through the forums and using google, but i take it my search skills are not quite up to par.
Havn't called GCG, I called up alot of the garret distributor's here in VIC, none had stock of the 9's. Apparently they are not as common as -7's...
Plus i made a bit of a mistake with Street to Track, I was informed today that the -9's were not available but the -7's were available for immediate shipment, so stupid me said to him to ship out the -7's impulsively after hearing that the -9's were not available. So now i think i will be getting some -7's in the mail...
Hopefully i can return them at get my $$$ back till the -9's come in stock.... I hope, otherwise i feel I am stuck with a inferior set of turbo's!
From the reading i have done, why get 7's when 9's are better?
So whats the big difference between them, while people recommend the -9's over the -7's. I don't think i have seen any facts/figures as to why they do.
Will either make 350?
Edited by Booki
I make 350 with -9s on 98, built engine though
I need to get my $$$ back. That is even assuming I can get them back...I mean I should be able too, I was thinking i could just send back the -7's and everything should be hunky dory.
Bit of a update, No refund avialable, but all good working it through with street to track, few miss communication's on my behalf.
I believe the correct turbo's i want are the Garrett GT2859R 780371 -1 or the GT2859R 707160 -9.
After reading through this mammoth thread http://www.skylinesa...lazy-gt2860-9s/
It looks like i need a decent set of actuators, are the ones included with the -1's alright?
I think i will be going a EBC as well, just to keep things stable. Looking at the Greddy Profspec 2.
Unless anybody knows of other Garrett turbo's that are superoir to the -9's? From the research i have done the -9's are better then the -7's in everyway (maybe not the exact same response, but 100rpm diff for more power seems like a good trade off)
EDIT: Re the recommended 1000 ID injectors, A buddy was telling me going to big of a injector can be a bad thing? It may give me a more rich tune, resulting in less power? Should i be going injectors that are smaller?
It doesn't look like there is much difference in price between smaller injectors of larger ones, It would make more sense to just purchase the bigger ones and be done with them.
EDIT: Re the fuel pump Bosch 044 intank install, Read the DIY, seems like a bit too much mucking around for me when you can get a pump that will go straight in? Walbro seems alright? http://www.kudosmotorsports.com/catalog/walbro-fuel-pump-kit-intank-walbro-gss341-255lph-nissan-180sx-rps13-silvia-ps13-skyline-r32-stagea-wgnc34-p-1079.html
The nismo is $594.....eeeeeeeeeeeeeeeeeeep! Man just can't catch a break $$$ wise with this car!
Edited by Booki
More of a update;
Tuner reckens stick with the -7's i have gotten...says there is SHIT all difference between the -9's and -7's in terms of overall power.
Says all the stock components are good for about 310rwkw, and running 20psi is bad for the stock internals, (well not bad but just shorterns the life quite a bit).
Reckens the biggest limiting factor would be having a poor quality cat.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
