Definitive R34 Gtt Wiring Pinouts
Attached is an Excel document which I painstakingly put together by hand, as I found some R34 GTT diagrams out on the internet either completely unavailable (bodyloom/m53/f3 plug) or unreliable (ecu pinouts)
Ive sacrificed an entire engine loom to get this mapped out correctly and Ive taken the liberty to add in all wire colours.
The first worksheet in the document is of what I call the 'body loom' plug or 'M53' or 'F3' plug if you are familiar with other Nissan looms. This takes all input/output from the ecu to non-engine related things. In the case of the R34 this is things like the auto trans control, traction control, dashboard outputs and inputs and power/switch feeds and triggers. I required a pinout of this plug as when going a full wire-in aftermarket ECU, many of your connections will be made at this plug. Nowhere on the internet could I find a correct pinout of one of these for an R34 GTT.
The second worksheet in the document is a standard ER34 (auto) ECU pinout, with all pins labelled as to their function and also the wire colour.
Enjoy, I hope this helps anyone who needs it. :)
R34Pinouts_Final.xlsx
  • Thanks 1
  • 1 year later...
hey man could use some help im tryn to wire a rb20det loom into my r34 dash loom plug this is the
m53 plug im sure ov it..is it the big long white plug just up from the ecu tht your writing about in your post?...
  • 1 year later...
  • 2 years later...
  • 1 year later...
Just wanted to say a big thankyou for putting this together, really appreciate it :)
  • 2 years later...
Reviving an old thread because I pulled the trigger on a wiring specialties harness for the engine side then went Haltech 2500 and a Haltech PD16. The idea being that the PD16 will effectively eliminate ALL of my fuse block and excess wiring.
I'm going to reference the excel in hopes of sorting out everything and if there's any additional information I discover I'll make and update the file. Though as others mentioned, Mitch did a great job sorting this out.
 Share
    • I can believe it if you're getting air into the pickup. Cavitation is tremendously destructive for pumps.
    • I think the pic in the first post is another car, and post 7 is OP's car with standard arms and swaybar swaybar swaybar. I can't tell what brand the silver coilovers are, and even if I could I don't know whether the spring rate is OK, if you can find a brand on the shocks and numbers on the springs that might help. Also, if you can measure the ride height from centre of your wheel to the guard that will help with advice too as handling suffers if ride height is too low
    • sadly, pics no work. that car must have spent a lot of time in a cryo bubble
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
    • Thanks for the info. Didn’t know I had aftermarket control arms already? Will talk to my garage. What brand would u recommend if I want to play around with my camber more? I would think my camber is around stock level right now or more negative now due to lowering with coilovers. I will be lower her again 1.5 cm to get some more.    also why does everyone like to remove the hicas system? Is it because most don’t work properly anymore or ppl just don’t like them. Mine is functioning as it should be right now.    thanks for the good info
