So send me your engine. Have you trolled www.importmonster.com in the yahoo auctions. Every now and then there are carbon/fiberglass bonnets . Swap your steel front guards for massa fibreglass ones (leks did this). Custom design your suspension arms out off aluminum (billet). Swap your glass for perspex. Convert to 2wd by removing front drive shaft. These should help your quest.
Edited by joshm35
  • Replies 70
So send me your engine. Have you trolled www.importmonster.com in the yahoo auctions. Every now and then there are carbon/fiberglass bonnets . Swap your steel front guards for massa ones (leks did this). Custom design your suspension arms out off aluminum (billet). Swap your glass for perspex. Convert to 2wd by removing front drive shaft. These should help your quest.
Carbon bonnet would probably be heavier than the OEM alloy version.
Same again on guards; maybe a kilo each, if that.
Suspension is already alloy. Maybe someone should do it in carbon?
Not really. It's just another way to make a car handle better. You are right that it may be a lost cause but you take 50/100kg out of any car the performance increase will be significant. Anyway, it's more about chipping away at performance from every angle possible rather than having to pump huge power numbers into them..
But all you're going to end up with is a noisier, harsher, less pleasant car to drive.
And it might accelerate a poofteenth quicker, or save a bees dick of fuel?
If weight saving was your primary concern; why on earth did you buy a Stagea?
If you do anything to your car that displeases me; I may have to kill you.
Lol, jokes. :whistling:
But seriously; don't. ;)
Not looking to run an empty shell but often there are simple ways to trim fat from cars.
I needed a wagon and I like turbo's, that's what i like about Stagea's.
If your talking race car.....
AC delete, strip all interior. Strip dash. Get rid of little interior bits, like struts, and tv tuner etc etc. Seat to fixed race seat. Get rid of the auto box, and go manual, it's got to be lighter.
But stagea does not equal race car. Just enjoy it. In modern terms it's not a heavy car.
Maybe Matt; but there are much better cars to focus this kind of attention on.
My car with a 100kg passenger, or two smaller passengers doesn't really go any better or worse, and with a bootful of holiday luggage; I'm convinced it handles better.
You're right about that. I find when I have a boot full of groceries that cars are less skittish. Wasn't a big deal but often there are often some simple ways to loose excess kilos and everyone helps. It may be my new family wagon but doesn't mean it can't fun when the wife and baby are not coming for the ride.
Just a better battery can save a little.. http://www.tuneruniversity.com/blog/2012/03/power-to-weight-ratio/
http://www.autoobsession.com.au/category/odyssey/odyssey-lightning-odyssey/
180sx: 1150kg and three times as powerful as your car.
You Jelly?
Considering that we are talking about V35s and M35s in this section and that the stagline is a mid size sedan and far more advancenot really hey
Oh and pulsar VZR N1, SR16VE 1090kg and 147kw factory...if we are playig that game.
But it's front wheel drive.
Edited by Daleo
Sound deadening in the floor pan. Mate striped 16kg of the shit out of a R32 sedan and theyre not as quiet as ours so i cant imagine how much of the crap is in ours.
You haven't looked under the carpet... Our floor pan isn't flat, and what is shoved in there is quite light.
swapping over to a energizer 9v will save some weight
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
