Hi all what would be the go with this what would I need to mod the head or the block? Also how and what would I do to do this.
Also I do not need anyone telling me to use a 25 head there is reasons why I am doing this I could work it out myself but want to fast track the process.
Thx for helpful responses in advanced.
Edited by pf.
https://www.sau.com.au/forums/topic/422697-rb30-head-on-25-block/
don't know if this is an april fools day joke or not. if it is, you posted it after 12pm, so it doesn't count.
why would you want to make an engine less powerful than stock?
as for what you would need to do to make it work, i wouldn't have a clue. i'm guessing that you would be one of the few people who have decided to go down the route of making a single cam rb25, given that the rb30 only made 115kw in 3L form, so dropping the capacity by 500cc will drop power down to well under 100kw at the flywheel (where as the standard rb25 makes over 140kw at the flywheel).
so sure, you may have your reasons for wanting to do this (which i'd like to hear), but the simple fact is that it is a bad idea and all of the replies you are going to get are going to say that too. you are better off using either the complete rb30 engine or a complete rb20 or rb25 engines. any of those three are going to make more power than what you are planning on doing. as well as being much cheaper.
Well I already have a 25/30 so I was going to recycle the leftovers. A engine builder has said he can build a 30 head to flow better for alot less in fact he believes the 30 head will flow better allround.
I do not want any talk of 25/30's as I already have one being built it will be turbo.
Edit at the end of the day a 25 or 6 head could flow better particularly the 26 head I doubt the 25 head would for n/a but it will cost a lot more money buy more I mean like 3 times the cost. The engine builder I spoke to said he could get me upto 350hp or more with a 30 head that is on a 30 block though.
Edited by pf.
Well the most I've ever seen from a built rb30 is just over 230rwhp (and it revved up to about 8000 rpm from memory), so to get to 350 would be extremely unreliable and probably require race fuel to get there (not to mention a metric shit ton of money). Unless he is talking flywheel horsepower, which would put you back at about 250 to 270hp at the wheels. Then take into account the smaller capacity, I'm guessing you might just crack 200 if you are very lucky.
But good luck with it. I'm happy to be proven wrong. I just hope you are happy with the results and don't blow a heap of cash and get nowhere.
Yea I am talking flywheel hp. The engine builder I am referring to has built 2v 6cyl race engines up to 350hp fly he said a rb30 build could see me at 350 fly I trust this guy's words.
Edit here is his words quoted.
BMW E20 engine, 2.8L, 2 valve per cylinder, SOHC, E85 fuel (I did the head & intake, specced the cam & provided specs for headers etc)
260rwkw (351rwhp) @ 8000rpm.
That 120% VE @ 8000rpm.
Tis only fed with 45DCOE's with 40mm chokes as well.
I predicted it'd peak at 7800rpm, so I got it wrong by 200rpm, I was short 40hp on my estimate as well.
Another engine that made exactly the same peak power (not a BMW engine) went on a engine dyno shortly after & made a tad over 400hp - so it's a pretty good bet this little beamer is doing about the same.
PS - 2.3hp/ci f**k yeah!
Edited by pf.
Oh yea I don't think he told me I could make 350hp but after seeing his recent builds I think he could but I am not using this guy. I have local mates that are builders so ill look around for a good head porter and get my mates to build it.
Edited by pf.
2891002-triple_facepalm_by_spottedheart9
ROFL, that's gold :rofl2:
RB30 single cam has bigger ports than any other RB ( including the 26 ) the problem is air velocity which is why 25/26 heads on 30 bottom ends work better in N/A form, loss 500cc and there would be very little air speed left
like previously stated by others, happy to be proven wrong so do it and post result
The 30 may have two big valves, but the 4 valves in a RB25/RB26 head mean more valve area which = more air flow = more power.
Secondly, 120% VE? BWAHAHAHA... You know this guy is trying to tell you that each time your 2.5L engine completes a full cycle, it's really taking in 3L of air... Or in a very simple terms, running 3 - 4 PSi of boost?
It's nigh on impossible to make an NA engine 100% VE, yet alone 120%!
Edit: I did some light digging, and it appears the RB30E runs a 42mm valve, while the RB25 runs two 35mm valves... (WOAH! The RB25 is smaller... Wait... We knew that)
What this works out to is the RB30E has roughly a 130mm^2 valve area (I have not subtracted the very tiny amount for valve part going back up to the head), whilst the RB25 retains a 219mm^2 valve area...
Now what does this mean... The RB25 for the exact same air speed, can actually draw in MORE air then the RB30... Or, to make this simpler, to get the same amount of air in, to make the same power, the RB25 has a lower air speed (The opposite of what you've said)
Also, if valve sizing was idential, an the RB25 had a high air speed (Like you've claimed) what you're actually saying is the RB25 head allows more air into the cylinder. This is good. Why is this good? Because you can shove more fuel into that cylinder, to keep the AFR identical. More fuel and air in the cylinder when it comes to ignition, means a bigger BANG... A bigger bang means more power.
You've provided yourself with all of the evidence as to why an RB30 head on a RB25 bottom end will be completely terrible.
Not to mention, there is nothing majorly different between porting an RB30E head, as to an RB25DE/DET head. Which begs to question, why is your engine builder charging you three times as much to port your RB25 head over what he says he'll do for the RB30 head?
You are new to engine dynamics by the sounds of this there are many factors that give a two valve head a performance advantage at a cost ratio to four valve head. Yes four valve heads can flow higher numbers but cost a whole lot more to build think about it I am going to use bigger valves so I only need half as many and so on down the valve chain. I'll edit in some other facts soon.
Quoted " You can't beat the quench & flame travel characteristics of a good 2V head, nor can you beat the pressure recovery characteristics & efficient discharge coefficient than can be achieved.
4V only have the curtain area advantage, other than that they are inferior in every way.
That curtain area advantage is a big one tho & makes up for the other shortcomings at higher rpm.
Bet most people don't realise the curtain area advantage is not as big as it looks on paper tho - valve to valve shrouding reduces the effective curtain quite a lot & the necessary placement of the valves requires more valve/bore shrouding as well, also direct acting cam on bucket setups are significantly lift limited compared to rocker arm setups.
A canted 2V head can place the valves away from the cylinder wall so that the curtain area available can be almost fully utilised with fairly even discharge around the whole circumfrence of the valve - that makes for a very efficient intake tract with little or no 'wasted' volume. Compare that to a 4V head with it's shrouded valves, which must have port/bowl area above them even in areas that are innactive - resulting in less efficient use of the port volume, lower pulse tuning 'signal' & lower velocity ram effect.
In short - a well developed 2V head can outperform a 4V head up to the point where curtain area becomes the restriction in the 2V head, from there the 4V will outperform.
Oh yeah, you also have excessive pullover & reversion on 4V heads - by their very nature low lift flow is good, too good in many cases, something that flows well in one direction usually flows quite well in the other direction, so at lower rpm 4V engines experience higher rates of reversion (that's why they are doughy down low, got nothing to do with big ports).
They also waste more potential trapped VE out the exhaust as that high low lift flow comes into effect at higher rpm during the overlap period."
Also with the ve-volumetric efficiency you do realise that the scavenge effect can draw air through the intake faster it is called induced exhaust sometimes. This is the whole Idea of using tuned extractors so the crate a scavenge which will induce air flow.
Do you even know that compression increases with rpm it is called dynamic compression this is what I mean by you don't understand the dynamics of a engine, you just quote paper figures.
Edited by pf.
Also a point I want to make is that making a proper tuned exhaust is so much cheaper and easier with a 30 over a 25 head yes this is not of concern with turbos but n/a it is. To make the correct exhaust for a 4v head you need some very good metal skills as a oval port just doesn't cut it for a high power tuned n/a exhaust, round ports are so much easier to cater for.
Edited by pf.
Also I never said he was my engine builder I would not send any of my parts to him, not due to his workmanship just because I think he is a cock. But I have my engine builder mates that are well and truly capable of building a donk I just need to send the head away for porting.
Well Al, you and your 1500HP GTR seem to know everything, so how about you f**k off and waste your money making no power?
You seem to like quoting a lot of stuff yourself, like quoting paper without actually knowing what you're on about yourself.
You claim in one post that the 25 or 26 head will flow more, then you go on to claim the RB30 head will. (It has to flow more to make more power, think about it for a minute)
I never said that a 30 head would outflow a 26 head I did say that it might outflow a 25 head. Now what I am saying is yes I can use a 26 head but this would put the cost up very high for the small gain it gives. Remember this is a leftovers engine I will build it right but I wont spend big on it.
My name is not Al I did not want anyone to know my name so I lied but I will be truthful my name is Pat Famington and I do not own a 1500hp gtr I just thought that would be funny to write :)
The reason I thought saying I had a 1500hp gtr would be funny is of course we all know here that it is nigh on impossible.
Edited by pf.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
